SAMSUNG TV LE37A656A1F
I NEED TO KNOW THE CODE TO SET MY SKY REMOTE . I CANNOT FIND MY TV IN THE SKY INDEX MANY THANKS JACK
SOURCE: sky+remote code for my lg tv
hi.ive got a rev 8 sky plus remote and a LG 42PC56 42INCH TV and the code is 0206.hope this helps some people
Posted on Jul 29, 2008
SOURCE: sky remote
Dear folks,
Not sure if you still need the answer but the code is 1174. I have tried it and it works -
have TV and SKY on press TV on remote
press red button and Select together until the red light on the remote flashes twice
enter the code
press the SKY button
It works!!
Posted on Jul 08, 2009
SOURCE: Code for sky + remote to operate bose cinemate volume via the sky remote ?
1356 something like that ;)
Posted on Sep 25, 2009
  • 325 Answers
SOURCE: what code do I use to set up my sky hd remote to
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
Posted on Oct 06, 2009
SOURCE: Sky remote control code for Logik L22LID648
It is 0206 - It works! :)
Posted on Nov 10, 2009
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
Oct 13, 2015 | Samsung Televison & Video
I need a code for a ue40d5oo0
on ur sky remote,,
  1. Switch on the TV set
  2. Press the TV button on the Sky Remote
  3. Hold down the Select and Red buttons for 2-3 seconds until the LED blinks twice
  4. Enter the digit code - 0646
  5. Press the Select button to store
  6. then press tv and check the volume if it works on sky remote..
    if u still cant do it go to
    http://www.skyuser.co.uk/tools/remotecodes/index.php
May 05, 2012 | Samsung Televison & Video
I need a code for my Samsung tv model LE37A456C2DXXU, to connect my Sky remote to the television. Thankyou.
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
Oct 16, 2010 | Samsung TV Set Top Box Remote Control
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
I have tried looking on sky for the code for my remote control for my LG 42pg300 tv and its not on there does any1 know the code for my sky remote?
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
also check the below link -
Good Luck!!
Thanks
Mar 19, 2010 | LG 42PQ30 42 in. Plasma TV
Lost the remote code for lc-32gd8e for sky
Mar 10, 2010 | LG MW-71PY10 71 in. HDTV-Ready Plasma...
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
Electro Med Services...
