Question about Tomtom NAVIGATOR 6 (1T50081) GPS Receiver
TOMTOM ACTIVATE CODE
HI NEDD ACTIVATE CODE O MOBILE TOMTOM NAVIGATOR 6 ANHS2 C2AFE PLEASE KATERIN_MATEUS@HOTMAIL.CO.UK
PLEASE THANKSSSSSSSSSSSSSSSSSSSSS
3 Suggested Answers
  • 5 Answers
SOURCE: photos of tomtom one power on fix
Attached is a sequence of photos on how to get to and change the power control chip - the one that is probably damaged. This is for the Tom Tom I repaired and yours could be different however, there will be a power control chip of some kind (check out the part numbers to see which one it is) and it will be this that is damaged and will need replacing. The Power control chip is the hardest to replace as you cannot get to the 'legs' to solder them. To remove the old one, just apply a large soldering iron bit (with a blob of solder on it to make good thermal contact to the top of the chip) and heat up the whole chip until it is free. Lift it off straight away with tweezers. Clean up the solder pads with solder wick and then apply a SMALL amount of solder paste to each pad. It is improtant that this is a SMALL amount and is equal on all pads so the new chip sits square and true when you put it on. Make sure the chip is in the middle of the pad patern and push it into place. Now for the tricky part....either usa a large soldering iron and heat the chip until it melts the solder paste and drops into place or, use a hot air gun with a small nozzle and do the same thing. Great care needs to be taken to ensure you do not heat up the near by parts so the soldering iron is best but you have to remove it as soon as the chip falls into place. The surface tension of the solder should centre the chip up if it is slightly out but you need to get it possitioned as good as you can before you heat it up. Take care not to move the chip as you heat it. You will need a fine bit in the soldering iron for the diode and any other parts you may need.
You should start with TT1 and work through to TT7.
As well as this chip, if the power supply went high (12 volts) then the zener diode on the input to this chip will also have been destroyed - you should see signs of this just by looking at the device (see photo TT6)
The most difficult bits are: -
Opening the connector to the LCD. This can be done by gently lifting up the PCB to see the connector on the back and then pushing up the 2 ends of the connectors white locking bar. Replacement is also very tricky but with care it can be done. As an alternative, you can remove the LCD complete by gently flexing the plastic surround to it and freeing the display from the case. It is then easy to disconnect and re-connect the LCD to the PCB.
Removing the tin cover from the back of the PCB so that you can get to the power control chip. This takes time and a hot soldering iron with good solder wick to remove the solder. Having liberated a couple of lugs you can remove the others by gently lifting the cover near to a lug and heating that lug to pull it through the PCB. Don't burn your fingers though!
The parts are easy to obtain from either Farnell or RS Components - RS have trade counters you can go to and Farnell have a retail side CPC you can find them at http://cpc.farnell.com/. If you have problems let me know and I will see what I can do.
Posted on Dec 17, 2008
SOURCE: Tomtom GO 700 Activation.
my tomtom go 700 did not startup and I could not backup the inernal memory as it was crupted so replaced the internal hardrive but now I dont have the map and my activation code I do have the device code all it apears is a red cross flashing I need to what was on the internal memory was it just the map or other softwares to so at least I can purchase another map or do I have to, it is crasy why tomtom put a 2.5 gig internal memory insted of external I just want to smash it as I am so upset
Posted on May 14, 2011
Hi i have a curve 8520 on orange im after the unlock code my imei is 354908048165456 please help andrewjohnhatton@hotmail.co.uk
Hi whether you want to unlock your blackberry curve 8520 mobile from orange network then visit onlinegsmunlock.com here they ask you the imei number of your mobile .finally they send you codes to unlock your mobile.
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Hi I need a restriction code for Nokia C3. IMEI number is 354844045792036 Please email ty_pawley@hotmail.co.uk thank you
Restriction code is the same as unlock code , so the good place to get a restriction code for your nokia C3 model mobile , just visit this site Onlinegsmunlock.com , here it gives you a easy instructions and methods for getting the restriction code for your nokia mobile from the network lock.......
Nov 17, 2011 | Nokia Cell Phones
Hi.. I have a 6300 nokia with imei number 356415022130660. Can you please send me the unlock code? sofitaylor@hotmail.co.uk. Thanks
For the best unlock code for your Nokia model mobile,
you can try this site http://www.wickedunlock.com/nokia-6300/rs11wp9/
It provides the step by step instructions and easy methods for unlocking your mobile phones........
Oct 26, 2010 | Nokia 6300 Cellular Phone
Hi I want to get Nokia C3 restriction code for free
Hii, my name is Martina, I have Nokia c3, IMEI is: 355933040097613. I have to unlock the phone by Tele 2 (Croatia) for T-Mobile (Croatia).Could you be so kind to send me the code on my e-mail: .itThanks :)
Sep 24, 2010 | Nokia 3110 Cellular Phone
What the activate code for vbagx 1.20
Hi
Just goto this website : http://www.vampent.com/activate.php
Enter your imei no and thats all
Hope this helps
Mar 10, 2009 | Nokia 6680 Handheld
Nokia 6500 slide
please help i need restriction code nokia 6500s-1
RM-240
0556236
IMEI : 354837022216953
in ORANGE UK
thanks.... please send to r1cute@yahoo.com
Apr 25, 2008 | Nokia 3590
Nck code for lg chocolate
hi, i want my nck code, please.
my phone is lg kg800 and my imei is 355424-01-125891-3.
my imail is silvamen_2@sapo.pt; help me please.
Thanks
Mar 18, 2008 | LG KG800 Cellular Phone
Tomtom NAVIGATOR 6 (1T50081) GPS Receiver Logo
83 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
