Question about Speed Queen AES68AWF Gas Dryers
Speed Queen dryer does not heat...
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go. What's the problem? Could it be that it needs new coils?
  • Anonymous Mar 21, 2014
    the coil is good not sure what else could be wife said timer wasnt moveing
    the heat coil is good but wife says timer wasnt moving
  • 318 Answers
You have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Posted on Dec 29, 2008
  • 3 Answers
There are two sensors( not counting the igniter) for gas to flow. One is the thermostat witch warms and send a signal that the burner is lit so gas continues to flow. It could be defective giving wrong resistance value to control board. The other sensor works in series with the thermostat. It controls the maximum temp. of the burner. The burners are constantly cycling on and off to keep the dryer at a regulated amount of heat. Without the max temp sensor, the burner would be on all the time, get too hot and start a fire. It's a saftey device. It could be defective turning off the gas prematurely. Also check the igniter. The smallest crack in it , even though it is still glowing, will change it's resistance value and could keep gas from flowing. Good luck.
Posted on Mar 12, 2012
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 30, 2011 | Dryers
Dryer works except there is no heat. Gas line is open and looks fine, what could be the problem?
Hello there and thank you for choosing fixya
This is a fairly common problem with gas dryers there are several components that need to be checked thoroughly i will list them here below ok?
Quick Gas Dryer Tips:
Problem -
Answer ( most common ) -
Replace the coils on the Gas Valve.
Problem -
No flame, no igniter glowing at all,
Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
Apr 27, 2011 | Kenmore Elite HE4 Electric Dryer
Oven won't stay heated, clicking noise like its trying to ignite, and gas smell.
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Problem -
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Ovens
What to do when dryer runs but does not heat up
- glow bar igniter, thermal fuse , coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Problem -
Problem -
Aug 10, 2010 | Whirlpool LGR5636L Gas Dryer
My dryer runs but no heat what should i look at first
There Could be many Reasons but i would Classify it into 2 Parts :-
1. If there is NO Flame, No Igniter Glowing, then Inspect igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter when dryer should be calling for heat.
2.
Gas flame comes on first few times then quits and igniter keeps cycling on and off but never lets the gas go, then Replace the Coils on the Gas Valve.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 04, 2010 | GE DCVH515GF Gas Dryer
Dryer turns and air blows, but no heat. GGQ8811KQ0
Make sure that your dryer air vent is not being blocked by lent, and if it is not it is your element or thermocouple?
Nov 07, 2009 | Kitchen Ranges
Wirlpool gas drier flame comes on for the initial start then goes out and wont come back on to finish drying clothes?
Problem -
http://www.applianceaid.com/gas_dryer.html
I had a problem much the same as you and replaced the coils. Works like a charm now.
Mar 31, 2009 | Whirlpool LGR7646E Dryer
Speed Queen AES68AWF Gas Dryers Logo
1,102 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
