Would someone have this information and send it to me Thanks, [email protected]
SOURCE: Can't connect to the Internet via router
Well, this is a very generalized problem that others have, so i'll give you some starting tips. If you can connect when you plug your computer directly into the modem, then it sounds like your modem is bonding to your computer. There are a couple ways to fix this. The easiest is to ask your router to clone your MAC addess (not to be confused with a mac computer, a MAC address is a 10 digit code that uniquely identifies your computer on a network). See the attached image to find where it should be.
Once you set it to clone your machines mac address, unplug the computer from the modem, and plug in the router. If this doesn't fix it, please comment back and we'll try some other things. If it does, then give a good rating :-)
Steven
SOURCE: user manual for cisco 1800
1800 series is a MSR (Multi Service Router) with that you can build a network with voice,data and enhanced security. In selected models Wireless is also available.
Check the manual in the following link
http://www.cisco.com/en/US/products/ps5853/index.html
SOURCE: I need to update firmware for a MR814v2 wireless
Please visit the following link to download the firmware :
http://kb.netgear.com/app/answers/detail/a_id/625
A. Open the router page using the following way:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
B. Please follow the steps to upload the firmware of the router:
1. Under Maintenance, click router Upgrade.
2. Click Browse and locate the upgrade file.
3. Click Upload.
4. Wait for the router to reboot.
5. Click on 'Logout' (at the bottom of the list) from left menu
SOURCE: just purchased a Cisco Linksys
make sure you
1.install the router properly with Cisco Connect software
2, turn on wireless modem in you PC
3. check the signal receive status are found and connected.
if you still can't solve the problem you can get more technical information here.
