Question about KDS K717s 17" LCD Monitor
Monitor does not want to come on
I have a July 2005 KDS Model 700P that just started to not come up. I have checked all connections and there does not seem to be a problem. Is it replacement time? What is the usual life of a monitor? Thanks.
Joe
    Renaissance:
    An user who is expert in 3 categories / brands.
  • KDS Master
  • 848 Answers
Monitor does not want to come on? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Posted on Jan 03, 2015
  • 741 Answers
Before you take it in to be repaired check one more thing. Click on Start>Right-Click on My Computer>Properties>Hardware>Device Driver. Find your Monitor on the list of hardware devices. Expand it by clicking on it and right--click on your model to update driver. If this does not work then yes, there are two small flourescent bulbs inside the moitor about 8" long and size of a pencil. Those do burn out and can be replaced. However, before you spend money on repairs check for reburbished monitors at websites like TigerDirect. They have new refurbished 19" monitors for a little over $100, Hope this helps.
Posted on Dec 29, 2008
KDS K717 MODEL 700P MONITOR works dimly for a second or two and then goes blank.
Your monitor has faulty light bulb(s). Replacement is hard.
Apr 07, 2012 | Computers & Internet
I need the 15pin/28pin cable for my kds 700p monitor , where can I find one?
The most likely place to find one is a computer repair store.
Mar 18, 2012 | KDS 17" .25 XF7I Monitor
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
KDS product 17s, model 700p. I am getting the follwing message "mode not supported H 82.8khz V77.7hz" whenever I boot the computer. I cannot escape from the message. The computer it is attached to is...
Start in SAFE mode (press F8 wile booting) and choose SAFE mode from the menu to see if it works in Windows DEFAULT setting. Then reboot and reset to 32Bit, and 78Hz max.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Good Luck!
Let me know if this fixes it
Mar 26, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
Twelve years is a lifetime for a monitor.
May 15, 2017 | KDS 17S 17" Monitor
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Can my KDS (#K717S-700P) monitor be wall mounted?
This monitor can be wall mounted but I do not know what bracket you would use.
If you look on the back of the monitor you should see 4 indents in the sticker near the corners. If you don't then rub around near the corners of the sticker. With a sharp knife or pin you should be able to lift out these tiny stickers. You need to measure the distance between these on the horizontal, vertical and diagonal then you should be able to ask somebody at your local TV dealer for help locating the correct bracket.
I'm sorry i can't be more helpful.
Nov 24, 2008 | KDS K717s 17" LCD Monitor
KDS K717s = Radius-73 Model 700P
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
srich
May 27, 2008 | Gateway FPD2275W LCD Monitor
KDS K717s 17" LCD Monitor Logo
212 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
