Question about Dell Precision 670 (670MIN) PC Desktop
Power shuts off and takes several minutes to turn back on
My Dell precision 670 shuts off after some amount of use. I can't turn the computer back on for up to an hour. During this time I see the light on the mother board comes on periodically for a second. Eventually the light comes on and stays. Then the computer starts working normally.
I called dell and they said it is power supply. But the power supply seems fine because it comes on after a while and once the computer comes on it works normally unless I keep the computer on for too long.
Help please.
Thanks
    Scholar:
  • 51 Answers
You're right, it's not the power supply. Your CPU is overheating either due to a broken heatsink hold-down or ( more likely ) a bad or stuck fan. Open up the case and make sure no wires are jamming the CPU fan. It has to spin freely and run when the PC is powered up. If the fan is O.K. you'll have to remove and inspect the heat sink. Make sure the physical mounting is firm. This is not for the faint-hearted. You should clean the mating surfaces and apply NEW heat sink compound.
Posted on Dec 29, 2008
    President:
  • 948 Answers
If the computer is overheating, those are the symptoms that would happen. Turn on your computer with the cover off. Are all the fans working (even in the power supply)? Is there a lot of dust build-up anywhere? Can you try another power supply? You need not install it in the computer case, just hook up the connectors with the known good power supply just outside the case and try it. Is your processor heat sink securely connected to the processor?
What causes a Dell Precision one beep then shuts down?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Bios beep codes to many popular systems are given.
Aug 08, 2014 | Dell Precision Workstation 670 PC Desktop
Dell Precision workstation 670 - System is locked with a Bios password and now that has been forgotton. I have tried the one solution to power off the system, remove the power cord, drained it by pressing...
If this is a PC follow these steps.
1.!!! IMPORTANT !!!! Turn the computer off and unplug it.
2. Open the tower and locate the mother board. This will be the largest board that everything is link to.
3. You will see a watch like battery, remove it.
4. Wait 30 seconds to a minute.
5. Now replace the battery and close the tower
6. Power up the computer and your login request should be removed.
This maybe the same for laptops
Nov 05, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
Bios update for Dell Precision workstation 670 & instructions?
DONT EVER UPDATE BIOS....99.99% IT WILL MAKE UR PC A DUD....MFGS DONT MAKE NEW UPDATES FOR OLD BIOS...AS BIOS CHIPS ARE HARDWARE MFG SPECIFIC...IF U STILL WANT TO DO...U NEED TO BE 1000000% SURE OF WHAT BIOS IS IN UR MACHINE AND WHAT BIOS SOFTWARE IS INSIDE THAT.....EVEN I AS AN EXPERT DONT ATEMPT IT....AS ANY CHANGE TO BIOS IS DIFFICULT TO REVERSE....
writing in all caps amounts to shouting....
sorry i wrote it in capital....not ment to shout at u...
just warning u
Sep 26, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Can I use a SL8MA 2.8 dual core 4mb / 800 fsb processor in a dell precision 670?
I know this is late but it is the CORRECT answer.
Dell used different motherboards in the Precision 670 and they are listed as follows:
X0392XC837MG022U7565
I am running the XC837 motherboard and it WILL support the SL8MA processors. I have been told that the XC837 is the ONLY motherboard what will support the Dual Core Paxville Processors. If you are trying to use them in a 470 you will need XC838 Motherboard.
Nov 25, 2009 | Dell Precision Workstation 670 PC Desktop
My Precision 670 won't power up. The power light flashes amber. I have checked to make sure the power cable is securely connected to the system board, don't know what else to do.
If it not power up the first make sure power cable isgood try with other power cable.
Then check on cpu.reconnect ATX connector from smps to motherbord.
Pull cmos cell from motherbord for 10 minutes ..
Make sure your smps power supply unit of cpu is good.It is squarebox in back side of cpu .
If still not power up the smps has issue.
Let me know if you need further assistance.
Thanks.
Nov 05, 2009 | Dell Precision Workstation 670 PC Desktop
Computers & Internet Logo
322 people viewed this question
Alun Cox
