Question about GE JGRS14 Gas Single Oven
Sears Kenmore oven height
I just got a new oven from sears Its a Kenmore oven of 30" wide Does any body knows the height?
    Sergeant:
  • 311 Answers
I assume you dont have it yet.it will be close to what you have now they are all pretty standard.you can adjust the legs
Posted on Jan 01, 2009
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
Tip
SEARS / KENMORE Range/Stove/Oven Manufacturers
SEARS/KENMORE
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built your Sears / Kenmore Unit. This can be helpful if looking for repair or replacement parts.
Your model is manufactured by the following if your units first digits starts with:
Amana 596
Caloric 174 / 960
D & M 587
Fedders 484
GE 362 / 363
Gibson 253
Jenn Air 829
Kelvinator 417 / 628 / 662
Litton 747
Maytag 925
Roper 103 / 155 / 647 / 835 / 911
Speed Queen 651
Tappan 79
Toshiba 562
WCI 790
Whirlpool 106 / 110 / 198 / 562 / 665
on Jun 10, 2011 | Ovens
We just bought a Kenmore Elite Oven, model 4809, at a Sears Outlet Store. I've looked all over your website and cannot find dimensions or installation instructions. I looked at the online manual for the...
I just purchased the same model and have been searching on-line for the exact same information. Not sure if you still need it but the Sears Outlet website lists the opening dimensions for the Kenmore Elite Oven 4809 as Width 28-1/2 in. min., 29 in. max. Depth 23-1/2 in. Height 29-1/16 in.
May 01, 2011 | Kenmore Ovens
Ignitor for oven comes on but gas release cuilds up before oven ignites causing a voom
I have a Kenmore Gas Range, model 72503. #1 problem-the orficies were not installed properly; #2 problem-when I turn the top burners on, gas comes out before the ignitor comes on. I called Sears, they sent someone who said that the burners can't be adjusted. I feel this is very dangerous. This is a new 2011 model, made for Sears by Frigidaire. Who should I contact about this problem. Sears say it is out of their hands. Help!
Sep 12, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Model 278-4298892 Built-in oven won't heat
The oven temp. sensor has gone bad. Replace it and that will solveyour problem. The part # is WB21X5301 and cost is $73.49. Canpurchase at http://www3.sears.com/. You can view the image at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124160&brandID=0582&modelDesc=Free%20Standing%2C%20Electric&modelNumber=9114658815&documentID=00053545&documentTypeID=PLDM&documentClassCode=PM&titleType=BODY%20SECTION&titleID=00002&. It is inside the oven in the upper right or left hand corner. Shouldbe able to remove from the inside. Two phillips screws and pull it outharness also. Plug new one into harness and put screws back in and youare done.Also, on the image it is # 253.
Apr 10, 2009 | Kenmore Ovens
I have an older Sears Kenmore oven. It has the
the internal fuse is blown out and the circuit breakers gone short its a reparing job not a resetting job.you will have to opoen the oven and get the circuit breaker checked and repaired or replaced.
Mar 02, 2009 | Kenmore Ovens
Oven will not heat to temperature setting
Called a Sears Tech to check it out. He found it was the control board/clock/timer. He said it was the first one he had seen go bad, and was happy I had the part number from your site, as it did not yet appear on his computer.
Dec 31, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE JGRS14 Gas Single Oven Logo
567 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
