Question about Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape
DPFMate Software to big for screen cannot shrink to fit screen
It pops up on the screen but goes to left and up to far that i can not minimize the screen to download pictures and it will not let me drag to fit screen help!
  • ergsr1 Jan 21, 2009
    Installed NetViewer remote security camera software on mini laptop with 8.5in. screen. Can't get to the control buttons along the bottom of the screen. I can move the image up but when I release the mouse button image falls back below edge of screen.
2 Suggested Answers
SOURCE: DPFMate Software not available
After powerup hold down power button (just a second or two then release) to get to the menu go to usb connect press arrow and select yes. you should be able to explore your Digital Photo Frame (D.P.F.)as a usb storage device double click on DPFmate.exe It should startup manually then.
Posted on Jan 24, 2009
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
Nov 13, 2014 | Televison & Video
My DPFMate is showing a blank screen
you must flashing that because the system software is error
Dec 27, 2013 | Spectra DPF-105 Digital Photo Frame...
Error message - design to big- use multiple hoop embroidery-won't transfer to my machine for a large design
If you can get the Buzz edit software there is an easy fix. Open the design in buzz edit. Under the view tab, show hoop properties and select xl6000 hoop. Then again under the edit tab select all. next under the buzztools tab rotate the design 90 degrees. This usually takes care of the problem, don't forget to save as copy. If it is still too large, shrink the design until you see it fit into the hoop on the screen. Don't shrink it more than 10percent or your stitches will be too cramped. Hope this helps. I use it all the time. Using this you can use designs up to 5.5 x 9 inches
Aug 04, 2011 | Singer Professional Sew Ware Options 2.0...
Won't fit my tv screen.
try ajusting the zoom on your tv
May 26, 2009 | Microsoft Fable 2 for Xbox 360
Jan 15, 2009 | Sakar DIGITAL CONCEPTS VC-16 Motorized...
Finepix J10 software - view screen is too big and I can't see a lot of it
you may not have the best setting for your screen enabled
try
right click a blank part of the windows desktop
properties
settings, and check what screen resolutions are available, and choose a higer one
Jun 02, 2008 | Fuji FinePix 2650 Digital Camera
Picture too big for screen
GO TO MENU VIDEO SETTINGS AND RESET TO FULL FORMAT SETTING , GO TO JVC.COM AND DOWNLOAD THE OWNERS MANUAL GUIDE ,
May 16, 2008 | Televison & Video
Display problems
it depends on what type of PC you have but basically you can go to "my computer" and "display" - change the "resolution" to the next higher setting - this will shrink the screen to fit your window [dxh]
Oct 03, 2007 | Toshiba 32HL95 32 in. LCD TV/HD Combo
Sakar DIGITAL CONCEPTS VC-16 Motorized VHS-C Adapter D-VHS Tape Logo
354 people viewed this question
Top Sakar Electronics - Others Experts
Are you a Sakar Electronics - Other Expert? Answer questions, earn points and help others
