Question about Whirlpool GS6NBEXR Side by Side Refrigerator
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did not work (no motor running) and now is leaking through the end of the tube next to the lever. I just want to stop the leak because I don't use the water dispenser. I do use the ice dispenser, and that works just fine. How do I stop the leak?
  • 318 Answers
You have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Posted on Dec 29, 2008
My whirlpool ed20db ice maker isn't making ice. Inlet tube is frozen solid
Thanks for the model number. The water control valve=> W10245167 Water Inlet Valve will need replaced when this happens. Problem allows water to leak slowly into the ice maker and fill tube can become solid very quickly, or very messy ice formations coming down from ice maker, Thanks John Tripp Appliance 911
Jan 28, 2014 | Whirlpool Refrigerators
Whirlpool ref side by side.. water will not flow into ice maker so it makes no ice . Water does come out of drinking dispenser
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at jboooor@hotmail.com
Jun 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Water Dispenser not working and not producing ICE.
check the fresh water solenoid on the back of the unit theres a screen in the water line to it that maybe clogged also crak the line lose gently to isure water is passing through it if not? then change the water solenoid
Jan 15, 2010 | Whirlpool GS6NBEXR Side by Side...
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED22PW water not reaching ice maker or front dispenser
It doesn't matter if a whirlpool or any other brand is new or not, if you don't use an inlet water filter the water will taste like **** and sediment will deposit and cause catastrophic ice maker and water dispenser failure.
Feb 10, 2009 | Whirlpool GS6NBEXR Side by Side...
Broken ice maker
Make sure icemaker cycles. If it is most likely bad water valve
Jan 05, 2008 | Refrigerators
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
283 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
