Dryers Logo
Posted on Dec 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Duet Gas Dryer- burning smell
I have a duet gas dryer for the last 6-7 years. We have had no issues until today. I washed and dried 2 loads and each smelled like lighter fluid or the burn smell right after you light a grill. I checked the vent hose, outside vent, inside behind the lint trap (I vacum it out pretty regularly actually) and took the front panel off like you suggested to another person. It all looks clean. The smell does not come from underneith at all, only the drum. Now, we painted a floor with that gray paint last night in the room directly behind the dryer. The manual warns that it may smell funny if paint or varnish is near by, but there are 2 doors and quite a bit of space in between. The clothes smell aweful that came out. I am afraid to let my 2 year old wear them.
  • pianoman721 Jan 28, 2009
    I have been having the same problem lately with my electric dryer, the smell of lighter fluid coming from inside the drum.
  • lightersmell Mar 17, 2009
    i have the same problem with my electric dryer and gas stove. We did prime the basement walls which are below these appliances. I am wondering if it is from that? Did your odor go away?
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Answers
91
Questions
0
Helped
42714
Points
134
First is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
  • Anonymous Jan 04, 2009
    first is first ,,, disconnect dryer from plug,, now open bottom panel 2 screws ,, now go and get youre vaccum,shop vac, anything ,, reason for burning smell ,, usually catching on fire ,, we recommend do this 1 as year,,, after cleaning , put about 2-3 fabric sheets inside dryer and let it runn for about 30 minutes to remive smoke from drum,,, thank you
Dryer takes 2-3 hours ro dry a load of wash
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
3helpful
2answers
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
2answers
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
5helpful
2answers
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
huuum At your service!
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
62helpful
21answers
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Top Dryers Experts
john h
