Question about eMedia Music Corporation Guitar Songs Vol. 1 (eg06014) for PC
Emedia guitar master not able to run after installation
After clicking on icon in start menu a pop up says the macromedia projector has stopoped working ??
  • Anonymous Jan 05, 2009
    I have same issue
  • SaskTrapper Jan 24, 2009
    after clicking on icon in start menu a pop up says the macromedia projector has stopoped working ?? I am running vista,is it a vista issue?
Windows® Vista Error on launch:
“Director Player has stopped working” or “Macromedia Projector has stopped working” Most likely this problem is solved with the following steps:
  1. Click the “Start” menu and launch “Computer” from the right hand panel
  2. Navigate to the eMedia Guitar Master installation directory (typically this is inside your C: drive > “Program Files” folder)
  3. Navigate to the “Xtras” folder within your “eMedia Guitar Master” folder
  4. Delete the file called “SequenceXtra_1_9.x32”
Launch Guitar Master. It should open properly.
If the above solution fails to eliminate the problem, take the following additional steps:
  1. Click on the “Start” menu and navigate into the folder to the eMedia application.
  2. Right-click on the program icon and select “Properties.”
  3. In the box that pops up, select the “Compatibility” tab.
  4. Check the box “Disable visual themes.”
  5. If you can, check the box “Run this program as an administrator.”
  6. Click “Apply” and then click “OK.”
If you continue to experience problems with Vista, please make sure that your system is up to date. Download the latest updates for your operating system at support.microsoft.com. Get the latest version of QuickTime at www.apple.com/quicktime/download.
Posted on Mar 05, 2009
The program locks up with a message that " Macromedia projector has stopped working" but the message does not appear for a variable length of time. This is a Vista machine with a wide screen...
If you are running Windows Vista:
Right-click the 'hearts and spades' icon and select Properties from the context menu
In the dialog that appears, choose the Compatibility tab, switch on Run this program in compatibility mode for: checkbox and select Windows XP (Service Pack 2) from the drop-down list
Click OK thanks ... have a nice day.
Mar 10, 2011 | Computers & Internet
HI,
Macromedia Projector is a utility from Adobe (formerly Macromedia) which
bundles up a Flash visual presentation into a stand-alone EXE file, so you
can display the images on a PC without the Flash Player installed. Your
anatomy CD-ROM probably used Macromedia Projector to display its anatomy
pictures.
Macromedia Projector is not compatible with Vista. In order to run the
program, you need to set the Compatibility to a previous version of Windows.
In Explorer, find the main EXE file on the CD-ROM which runs the anatomy
program. Right-click the EXE file and choose Properties from the context
menu. The Properties dialogue will appear. Choose the Compatibility Tab.
Check the checkbox in Compatibility Mode, for "Run this program in
compatibility mode for:" and choose and earlier version of Windows - Windows
98 would be a good one to try. Then click OK to save the changes. Now
double-click the EXE file, to launch the program.
Once you have set the Compatibility, Windows Vista should "remember" to run
the program in compatibility mode, so hopefully you only need to do this
once.
Jun 22, 2008 | Video Game Consoles & Games
How can i get Macromedia FlashPaper 2 to work with vista and windows 7...Thank you
1. Right-click on the icon on your desktop or start menu. Click "Run as administrator"
Or.
2:
  • Right-click on the icon on your desktop or start menu.
  • Click "Properties"
  • Click "Compatibility"
  • Click the checkbox for "Run this program in compatibility mode for: and select "Windows XP (Service Pack 3)
Mar 07, 2011 | Macromedia FlashPaper 2 for PC
Upon starting program, a black screen appears with error message "Problem with Macromedia Projector" - goes no further
Good morning! Possibly, compatibility of the PC OS / VGA card to macromedia projector system is the problem. kindly check your computer system details and compared it to the system details of the macromedia projector. best regards.
May 02, 2009 | Computers & Internet
Emedia guitar method 1
Using a previous compatibility mode would be a stop-gap solution. The permanent fix would be to upgrade the software to a Windows XP compatible version.
http://www.emediamusic.com/support/upgrades.html
Sep 03, 2008 | eMedia Music Corporation Guitar Method...
Macromedia projector error
I had the "macromedia projector" error with the CSI game. This worked for me:
1). Open “QuickTime Preferences” (right-click the “QuickTime” Q icon in lower right corner of Windows taskbar).
2). From “Browser Plug-in” tab, click the button labelled “MIME Settings…” then click “Use Defaults” and hit “Ok”.
3). Now go to “Video Settings” tab and choose “Safe Mode (GDI only)”. (Note: QuickTime versions 7 and above, make sure “Enable Playback of Adobe Flash tracks” is also checked).
You should now be able to run the game without errors, good luck.
May 06, 2008 | Macromedia Flash MX
Each time I download csi crime scene investigations and begin to play I get a pop up of macromedia projector error and it ends my game every time so please tell me what is wrong to fix this problem.
You should un-install your macromedia flash player. Then reboot. After that install a new version. It will fix your problem.
Here is download for flash palyer:
Click here for Adobe Flash Player:
After Installation try to run your game......:))
Thanks
Iqbal
Mar 29, 2008 | Computers & Internet
Rhem 2 System requirements ok. Screen loads to menu. push play . next screen opens and when orange button automatically clicks, it says Macromedia Projector error... wrote down error sig C:\Docum~1HP...
When I checked the manual--the system requirements said to make sure i had QUICK TIME 6 FOR WINDOWS--installed. So I am going to try this----- they said to go to
hope it works and gets rid of the big red X
Mar 25, 2008 | Televison & Video
You might try reinstalling Macromedia Projector (now Adobe Flash).
Sometimes if you use compatibility mode to run the game:
  • Click - Start, Programs, Accessories, Program Compatibility Wizard.
  • Follow the prompts to set up the compatibility mode.
  • Use Windows 98 compatibility, and disable visual themes.
Also you could change Apple Quicktime to run video in Safemode:
Quicktime Player > Edit > Quicktime Preferences > Advanced > and under Video Change from DirectX to Safe Mode (GDI)
You may need to reinstall Quicktime, but uninstall the old version first.
Nov 20, 2007 | Computers & Internet
Macromedia Flash
I am wrting in regards to my Sony Handycam DCR-HC36. I am having problems with the Picture Package software when I try to load my video. When I try to transfer my videos (from my Handycam) to my Pesonal Computer, the picture package(software) menu does not appear on my PC(The picture package software is already installed).
Everytime I try to click on the Picture Package Icon on my desktop, there is a pop-up that says I "must install Macromedia Flash Player for Application to continue".
I went ahead and installed the Adobe (Macromedia) Flash Player and it still doesn't work when I try to click on the Picture Package Icon. The pop-up still comes up. I also, re-installed some of the requirements for the for the camera to work such as Direct X and Windows Media Player.
I also enabled my Javascript(active Script).
The problem is most likely within my PC(maybe I'm missing another type of software???), what do you think are my options in resolving this matter?
Please help me out
Anindya
Apr 20, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
eMedia Music Corporation Guitar Songs Vol. 1 (eg06014) for PC Logo
601 people viewed this question
Top eMedia Music Corporation Computers & Internet Experts
David Payne
David Payne
Are you an eMedia Music Corporation Computer and Internet Expert? Answer questions, earn points and help others
