Question about Viking DDBB363 Bottom Freezer Refrigerator
Viking VCBB362 I turned the unit off to get rid of ice build up in the freezer. I turned the unit back on but the compressor did not come on. There is a code sequence on the electronic control board to manually start the compressor, do you know what it is.
  • Anonymous Mar 22, 2009
    There is power to the unit but nothing is getting cold.
  • 59 Answers
Press Display on
then press and hold Max Frz and Display off, you should hear 3 beeps and the compressor should start.
It may also be that when you turned the unit off you hit the showroom switch that is located up behind the top grill, the power off switch is also in here.
The easy way to tell the difference is see which one turns the lights off, the showroom switch will not affect the lights.
With the lights on switch the other switch and leave it for 6 mins to see if the compressor, if not repeat.
Posted on Mar 04, 2009
Viking refrigerator freezer bottom mount. frost builds up on back wall behind cover panel in freezer. once we self defrost, runs great for 3 weeks and again we defrost with a hair dryer.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 09, 2011 | Refrigerators
I HAVE A MAYTAG UPRIGHT FREEZER THAT DOES FREEZE . IT RUNS BUT DOES NOT GET COLD
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Water leaks under viking professional and there is about a 1/4 inch build up of ice on floor of freezer(which is on the bottom) on the floor of the pull ot freezer
Your drain is plugged. Basically the freezer goes into defrost and melts frost off the condenser coils. A big piece most likely fell off and freezer came out of defrost before it coulld melt and drain out completely. To fix you have 2 options. Have towels
#1- move contents of fridge and freezer to a backup fridge. Leave unpluged with doors slightly opened for 24 to 48 hrs. Use towels to cleanup any water. Plug back in wait 2 hrs to make sure temp gets back down before putting contents back in fridge.
#2- Remove contents from fridge and put in ice chest. Have towels ready. Remove ice maker ( if there is one) usually two screws on top hard to see and one on bottom. Disconnect the quick connect for the ice maker. Remove screw on back wall. Be careful when removing air vent on back wall. Its plastic and can break. Remove back panel. Look on the silver plate under coils and you will see ice and where the drain is. Remove ice than pour hot hot water down drain until it flows freely into drain pan under fridge by compressor. It may look like there is not ice make sure othyerwise you will be doing this all over again in a few days. Once water flows freely put everything back together wait about 2 hrs for freezer temp to get cold enough and than you can put contents back in freezer. If you have any question or need help please feel free to comment me back.
Jun 05, 2011 | Viking Professional Series VCBB36 Bottom...
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
42" SxS Viking Not making ice
You may have to unplug the the unit and thaw it out with a hair drier,and get everything dry.Then close it up and set the temp,and plug it in.It will take a while before it will start producing ice again normally.If I can help,let me know.
Jul 19, 2009 | Viking 42 in Built In Professional...
Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Freezer doesn't keep ice cream frozen
not being able to keep ice cream is not good, before doing anything ck a few things. make sur e to pull out unit and vaccuum under and behind unit, if it cant breath it cant freeze. check in back by compressor, is the fan running to cool the fan??? if the compressor is on so should the fan be. next id look behind the freezer wall for excessive build up of frost( it might even be buildin up with ice throughthte back wall, inwhich case you have a defrost issue
Apr 02, 2008 | Refrigerators
Viking DDBB363 Bottom Freezer Refrigerator Logo
605 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
