ASUS P4S533-X Motherboard Logo
Anonymous Posted on Sep 29, 2012
Upgrading from 64mb card into 128mb or 512mb card. should i remove the component (64mb card) from motherboard? pls help. thanks.
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Sep 30, 2012
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
487944
Points
8243
Maybe you are referring to the video card? Or even RAM? If it is RAM you should definitely be using the 512MB (4 X 512) by this time. It is an older board, an ASUS (USA) no longer has a detailed specs webpage for this model. Make sure to check your manual.
Found this one:
http://reviews.cnet.com/motherboards/asus-p4s533-x-motherboard/4507-3049_7-30641017.html
1 Related Answer
A
Anonymous
  • Posted on Apr 04, 2008
SOURCE: ATI 9250 AGP8X 128mb TV out DVI graphics card
cheese is not good for you.
Types of sdram
PC66 SDRAM
PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB.
PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB.
PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
1helpful
What AGP is compatible with my ECS KT400 motherboard and AMD Athlon 1900+ processor? I currently have NVIDIA Geforce2 MX 400 64MB and I want to upgrade it to 128MB or 256MB.
Any AGP card is supposed to work. Doesn't matter what spec. Don't expect huge performance increases by just upgrading gfx card. Games might run better visually.
Cheers.
Please rate.
1helpful
Beeping on start up
Your motherboard has 64Mb built-in RAM and the video card needs some video RAM and has grabbed 8Mb of RAM which leaves the system with 56Mb of RAM. When you insert a 64Mb RAM module you have a total of 128Mb of which the video has grabbed 8Mb which leaves the system with 120Mb.
You can't change stop the video card from grabbing 8Mb of RAM, the RAM is essential for the video to work.
You can upgrade the RAM by removing the 64Mb RAM module and insert a 128Mb or 256Mb RAM module. You may even be able to insert a 512Mb RAM module if the motherboard will accept it, you need to check the specification of your laptop to see the maximum amount of RAM the laptop can handle.
Can't install 128mb of video card in Asrock k7vt4a+ motherboard
It is possible that Your motherboard does not support a video card greater than 64 mB. Check the motherboard specs.
2answers
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Can you expand the memory on a Systemax Intel SIS651 System
Your motherboard is actually a Foxconn 651M03.
According to your system you have :
512MB DDR333 PC2700 Non-ECC Memory (512MB x 1)
(One stick of 512MB)
The motherboard manual says this:
System Memory
Two 184-pin DDR DIMM slots
Supports PC1600/PC2100/PC2700 memory
Supports 64Mb/128Mb/256Mb/512Mb technology up to 2GB
(This means you can have a total of up to 2 Gigabytes of RAM)
If you upgrade your RAM, you will need to make sure that you get the correct type.
If you want to keep the RAM you have, you will only be able to have 1.5 GB of RAM because you only have two slots to work with. If you want to upgrade to the full 2 GB, you will need to buy 2, 1 GB sticks.
3answers
Upgrading hard disk
yes of course it will handle a 40gb hard drive..your P3 will handle a hard disk up to 60gb...coz i have a friend, his using a P3-700MHz,512mb, 64mb video card and barracuda 80gb hard disk=.)..to make it sure..bring your P3 to the computer shop so you can also know if your P3 is handle a 40-60gb hard drive..thanks..
3answers
ASUS P5VD2-MX SE video memory sharing
The message on the user's manual only indicates the possible maximum memory that can be shared with the video while in your bios you can see the actual shared memory. I think this could be case to do with the graphics card you are using i.e. is it onboard or an add on. In some cases too the manufactures of the motherboard are not the same manufactures of bios and therefore the manufacturer of the board has given it allowance to share up to 128mb while the bios manufacturer has given it up to 64mb. Remember many of the components on the board may come from different companies.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
