Question about JVC AV-65WP74 Rear Projection Television
Jvc AV65WP74 PROJECTION TV
How do you know if you need to order the IC (hybrid) - IC805 or IC804 CONV OUT? They both have the same part number STK392-110 from the JVC.com website. Is there any difference or does it depend on the model number or year my specific TV was made? Please help.
Thanks,
Amanda
  • nicegqman May 11, 2010
    How do you get to this part.Will front panel come off easy.Where is part located.Thanks
Just make sure they are stk392-110 I have the same tv and I just replaced them, I used generic chips and I have the same tv, also check on that board for burnt resistors alot of the time they go bad, there with be burn marks or or small cracks in them
Posted on Jan 05, 2009
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
2 lights blinking on my JVC 61"
need model number
usually reg or pwer conv ic
Dec 12, 2009 | Televison & Video
The TV has just started a red/green problem. The picture is double in the top and bottom of the screen with one image red and the other green.
you need to install a convergence repair kit. The AV48WP74-AV65wp74 convergence repair kit from www.tvrepairworld.com has the parts and the CD with instructions.
Dec 11, 2009 | JVC AV-65WP74 Rear Projection Television
Can I remove the base to this TV to move it?
Yes the set can be disassembled and then reassembled. But you would need the service manual that will explain how to get the set apart into seperate pieces. Heres a link to where you can get the service manual for your model they send it by download link.
http://servicemanuals.vstore.ca/product_info.php/pName/av65wp74/cName/jvc
Jun 15, 2009 | JVC AV-65WP74 Rear Projection Television
Looks ike conversion problem but lines are adjustable
HI, you will need to replace the hybrid conv Ic on the PC board. this is a digital convergence chip made by Hitachi and it is compatible to thsi set.
CLICK HERE
May 22, 2009 | Sony KP-53S75 53" Rear Projection...
Tv troubleshoot for me
chances are that IC804 has failed. You have two ICs that allow you to converge the three colors. IC804 is used for Red Horizontal and Vertical Convergence and also for Green Vertical Convergence. IC805 is used for Blue Horizontal and Vertical Convergence and also for Green Horizontal Convergence. These ICs run very hot and have a very high failure rate which sometimes will cause damage to resistors in their associated circuits. They are both STK-110 and it's best to replace them both at the same time. It's also a good idea to upgrade them to either STK-150 or STK-180. These will run a lot cooler than the STK-110.
Before replacement do inspect for any open or overheated resistors as I stated earlier. Being you only have problems with Red Convergence the plus and minus power supplies should be okay since they are common to both ICs.
Try www.tritronicsinc.com. They have the Hitachi CZ00433 (STK392-150) in stock for $20.11 ($32.43 retail). These are Hitachi OEMs. I've had very good results replacing STK392-110s with these chips. Do check for open or overheated resistors before replacing these chips
Dec 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Color convergence
RICKY-SOUNDS LIKE THE USUAL CONVERGENCE IC FAILURE.TRY LOOKING IN W/BACK OFF TV AND YOU'LL SEE COUPLE OF STK392-??? IC CHIPS,LOCATED ON A BIG METAL HEAT SINK.RETRIEVE THE EXACT PART # AND YOU CAN ORDER THEM AND INSTALL THEM YOURSELF IF YOU ARE GOOD AT SOLDERING ELECTRONIC PARTS,IF NOT BEST BET IS CALL AN EXPERIENCED JVC TECH.JOE TV
Nov 27, 2007 | JVC AV-48WP74 48" Rear Projection...
Ic replacement
Replace both IC's or you will re-visit later! STK-392-110 X 2....
Nov 10, 2007 | JVC AV-48WP74 48" Rear Projection...
Jvc 56wp30
1st guess is bad convergence ic-either IC804 or IC805. Both are part #STK392-110. May be bad connections in convergence circuit, or open resistor(s) As for too much green, not sure, shouldn't be because of convergenece circuit, possibly green CRT screen voltage needs adjustment.
Dec 22, 2006 | JVC AV-56WP30 56" Rear Projection...
Seemed to Fix Convergence problem; Now TV power doesnt work.
You need to check first for solder splashes or bridges created when the new Ic's were installed,the next thing to check is a disconected conector or might not in place fully and then check for loose conections in the main board,all that movement might have loosen something more than before,check the horizontal driver transformer,the horizontal output transistor.Be careful
Oct 02, 2006 | JVC AV-48WP74 48" Rear Projection...
JVC AV-65WP74 Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
