Question about Maytag MER5755QAS CleanDesign Electric Kitchen Range
Electric oven does not heat up enough
Maytag MER5755QAS CleanDesign Electric Kitchen Range when on BAKE, the oven does not heat up properly. It heats VERY slowly and never gets high enough. After 2.5 hours it only reached 250 degrees. It operated fine just 3 days ago, then the next time we used it we had this problem. What can I do to fix this? Thanks
  • 3 more comments
  • TTSE Dec 08, 2007
    Our oven is 2 years old. One week ago, the oven stopped reaching temperature. 50 minutes to get to 150 degrees. We checked the owner's manual - thought it might be a sabbatical setting. Reset that per the manual and saw no improvement. Also unplugged the entire unit for 5 minutes (hey, I don't see a lot of moving parts).
    Serious about replacing this unless we have a solution.
    Thanks,
  • lsleck Jul 07, 2008
    We have replaced the oven baking element but oven still does not heat up.
  • sddave Dec 23, 2008
    Ditto. Maytag MER5755QAW oven set to 'Bake' heats extremely slowly. Broil seems to work okay still. The unit is 3 3/4 years old. Any solution?
  • hkrlimi Dec 25, 2008
    My 2004 MER5755QAS range oven & broiler will not work at all. I choose Bake, set to 350 degrees & it reverts back to 100 degrees and just stays there. My range top works perfectly. Please notify me when a solution is found. Thanks in advance!
  • wayne106 Mar 01, 2009
    Ditto, Ditto. Maytag MER5755QAW oven set to 'Bake' heats extremely slowly.
    Broil seems to work okay still. The unit is 3 1\2 years old.
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Posted on Jan 18, 2009
Replaced the heating element and thermastat still will not heat past 300 deg and it takes over 2 hrs to do that
Posted on Jul 12, 2010
Oven is not heating
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 05, 2010 | Maytag MER5755QAS CleanDesign Electric...
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
Maytag Oven model MER5755QAS trouble heating up
your bake element could be burned out & the oven is trying to get to temp with the broil element only. see if it is getting warm or if it has a burnt spot on it. if it seems to be ok, you may have a bad oven sensor. the oven sensor should have a reading of at least 1100 ohms. let me know if i can be any further help.
Oct 13, 2009 | Maytag MER5755QAS CleanDesign Electric...
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
on a 220 volts stoves when the electrissity drops to 120 volts thats what it does.so oven element wires most be check for power, if it's getting 220 replace the element.
Sep 16, 2008 | Maytag MER5755QAS CleanDesign Electric...
Oven not heating
if that hi limit is bad or tripped you wont get heat.the hi limit should sit near the heater if not in it.if you find this is tripped your thermostat could be faulty.from the schematic try to trace the wires from the heater to the hi limit and then jump it out.let me know.
Dec 11, 2007 | Maytag MER5755QAS CleanDesign Electric...
Maytag MER5755QAS CleanDesign Electric Kitchen Range Logo
2,188 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
