Washer makes noise. washer motor stops and seems overloading. belt is three years old but has no cuts or cracks.
  • Washing Mach... Master
  • 8,220 Answers
Posted on Dec 29, 2008
Wtw5640xwi
see this causes and fix it. God bless you
Tub Bearing If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced.
Clutch If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drive Motor If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault. Replace it.
Tub Seal and Bearing Kit If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem and the parts are relatively easy to replace.
Rear Drum with Bearing If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley If the washer is making a loud noise the pump may be worn out, or something might be caught in it. Remove the pump and inspect it for debris. If it is clear and the blades spin freely the problem might be somewhere else.
U-Joint Kit If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission
Oct 16, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the...
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Apr 01, 2011 | Karcher Garden
LGWM2277HW Front Load High Efficiency set Code "LE"
may be a belt problem since you have this sound
thank you
Jun 21, 2009 | LG WM-2277HW Front Load Washer
My washer makes a loud noise during a normal wash cycle.
If it is a belt driven machine, then there's the smell. Lean it back a little, enough to fit a paint can under 1 corner and you can feel the belt right on the bottom. Feel for cracks, flat spots or a lot of black dust. Remove belt and make sure everything that it goes around spins free.
Mar 17, 2009 | Maytag PAV2300 Top Load Washer
GLTR1679 WASHER MAKES BANGING NOISE ON SPIN CYCLE.
Check the strut assembly. also a bad bearing can make banging noise.
Oct 31, 2008 | Frigidaire GLTR1670A Front Load Washer
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Squelling noise
Check the water pump. Remove the belt and turn the pump by hand in both directions. If there is a problem you will feel the pump try to grab. A lot of times some small objects that get in the washer and end up in the pump and causes everything from clicking noises to full stop.
Dec 03, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
