Question about SanDisk Sansa e250 MP3 Player
Sansa screen One night i was listening to music and my sansa screen was just fine and i hadnt dropped it for awhile. the next morning i turned it on and the screen looked broke...it was white with a big black spot in the lower left corner. i could still listen to music but i couldnt see anything on the screen. when i let it sit for a little bit you could just barely make out some words but after listening to it for a couple minutes you couldnt see anything at all.
  • NotUrGirl93 Feb 22, 2008
    my sansa e250 still plays music but wen i turn it on there is no screen not white or any lines at all!!! just all completely black! what do i do?? i have even tried to take out the battery plugging it into the computer nothing seems to work..HELP PLEASE!!!
Break something under warantee and send it in
Posted on May 12, 2007
My Sansa Clip lost all the music I had stored. It
You go to Settings, check System Info, check number of songs in there. If they are existing, you should change to MTP or MSC to play it. Or go to Settings, Reset All, Yes. Try it.
If you accidentally formatted it, can't restore them.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Can't add or remove music off my Sansa Rhapsody 2GB
first try this...
1 put on hold and hold record button while u turn on (your sansa is now in recovery mode)
2 connect your sansa to your comp via usb cable a box should show up saying the firmware version
3 close the window and disconnect your sansa (it will restart)
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa e250 MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Screen says its disconnect it won't change ....
your might have to let the battery die down completly
then connect it again and see what happens
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Brand new unit ...battery (or unit) died.
it sounds like the battery.but if new batterys dont work.then its the unit and you need to take it back.
May 13, 2008 | SanDisk Sansa MP3 Player
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
Connected - disconnected
i have had my Sansa e260 for about 6 months and while i was listening to a song it kept saying Bad track , Bad track , i got worried so i shut it off. Now its alsost like the power button is being held in it keeps showing the screen that comes on when you turn it on. When i plug it into my computer it doesnt even show up on the Monitor. i dont know what happened to it or how to fix it. Please HELP!!
Feb 22, 2008 | SanDisk Sansa e260 MP3 Player
Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
