Question about Zanussi TD4212W Electric Dryer
Squeeking Dryer tub
Sounds like the dryer squeeks in the front. I squrt a littlt wd40 in the track and it stops for a littlt wile. How can I fix this for good?
  • 20 Answers
Is the dryer leveled properly?
Posted on Apr 21, 2009
My kenmore heavy duty extra large capacity 2 speed motor when drying my clothes squeeks when turning to dry clothes can I spray wd40 to make it stop squeeking and how or what do I oil?
Most likely a wheel bearing on the tub of a front loading washer, or the belt tensioner pulley on a top load washer. Either is not fixed by lubrication but replacement is called for. There are usually 3-4 wheels on front loaders that could be out. Replace all of them if you are going to replace one. The belt tensioner is a single assembly that can be ordered from any appliance parts warehouse or Sears.
Aug 01, 2012 | Kenmore Washing Machines
The belt in my dryer is squeeking. What type of
It's probably the front tub guides that are worn out causing the squeak. It's a felt lined circular shaped guide that holds the front of the tub. The rear of the tub is held by a ball and socket bearing. Access to the guides is behind the front panel of the dryer. Remove the screws across the top
May 10, 2010 | GE Spacemaker Washer and Dryer Electric...
Dryer is squeeking and does not tumble on heavy loads
It sounds like the belt is gone....
Also check out this tip about your problem...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Mar 28, 2010 | Frigidaire Dryers
Dryer is squeeking Drum is tilted down in front. Drum is not sealed to front panel
Sounds like you lost the lower roller/mount for the dryer drum.
SearsPartsDirect online should have a parts breakdown for you so can spot the part in question.
Jan 16, 2010 | Kenmore 62872 Electric Dryer
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Squeeking noise when dryer barrel or blower wheel turns
Sounds like the fan blade hub has become worn. Remove the front to gain access and secure a hose clamp around the hub. It may be necessary to trim away some of the plastic vanes to allow it to fit snugly.
Apr 26, 2009 | Dryers
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squeeking noiseGE DCVH515EF
Replace front bearing-Felt bearing wears out drum rides on plastic frame.
Mar 08, 2009 | GE DCVH515EFWW Electric Dryer
Squeeking noise
it could be the bearings going out on the tub from the sounds of it
Jan 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Zanussi TD4212W Electric Dryer Logo
124 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
