Question about Tomtom (9K00.005) (636926011532) Mounting Unit, Vehicle Mounting
I have a tomtom125 and the screen shuts down after 30 seconds and won't come back untill I touch it again?
    Sniper:
  • 171 Answers
Don't really know about your model, but try going into change preferances and restore your tt to factory specs. This will delete all your setting but then you can start from scratch.
Hope this helps
Posted on May 04, 2009
I turn my Apple Ipad on and select a game...30 seconds later it shuts down
Make sure your battery is fully charged or just run with a power cord. Also, the battery could be bad.
Dec 05, 2017 | Apple Cell Phones
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
No SDCARD
First thing to try is another SD card.
May 10, 2013 | GolfBuddy World GPS Range Finder -...
My my touch 4g slide won't turn on. when i start it i feel a vibration but screen will not turn on. Help?
Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 11, 2012 | Cell Phones
What to do? touch screen just stopped working? worked, and then 30 minutes later nothing...turned off/on several times, can't enter PIN or push "view map".
Try to remove the battery and re insert it back in to see if it will work. Or hold down the power on/off for about 15 seconds, that should do the job.
If that does not do it, then calibrate the screen, to calibrate the screen, follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Dec 24, 2010 | Garmin nuvi 255W GPS Receiver
My power save came on, which turned my laoptop screen off, i moved the mouse, the system started up again but the screen remains black/very dark . the only way i can see my computer screen is if i connect...
It sounds like a driver recovery issue, you may have to do a hard reboot. Hold the power button in for atleast 10 seconds or until your laptop shuts down completely, wait 30 seconds then turn it back on. If this fixes the problem you need to upgrade your video driver and/or your Operating System.
Mar 24, 2010 | Computers & Internet
The screen shuts down after between 30 & 60 secs
This is an option for the TomTom. If you enter the Options, there should be something about Power Save features. In there, you will see options to shut off the screen, and you can have it do so after a certain time, once a certain speed is reached etc. Just change the time in which it turns itself off to never and you're fixed.
Sep 30, 2009 | Tomtom ONE GPS Receiver
Right side of i touch screen non-reactive
Perform the under given steps to troubleshoot the issue:
(i) Clean the iPhone screen with the cleaning cloth that came in the box with the iPhone.
(ii) If you have a protective plastic sheet or film on the touchscreen, try removing it because it may be preventing the touchscreen from working properly.
(iii) The current application may not be responding (frozen), press and hold the Home button below the screen for at least 30 seconds, until the application you were using quits.
(iv) If that doesn't work, turn the iPhone off and turn it on again. Press and hold the Sleep/Wake button on the top of the iPhone for 30 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
(v) If the iPhone did not turn off, reset the iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for a least 30 seconds, until the Apple logo appears.
If the issue persists then service will be required.
Sep 08, 2009 | Apple iPod touch
Tomtom (9K00.005) (636926011532) Mounting Unit, Vehicle Mounting Logo
235 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
