Question about Hifonics BX1500D Car Audio Amplifier
Hifonics 1605 Amp worked for 2 years and about a month ago she stopped working. I opened her up and about 10 of the voltage regulators are out I can solder fine. Everything comes on accept the power light, instead the protect light comes on. I need to know if anyone can provide the type of voltage regulators this amp uses. +5v, +12v, or adjustable. Or the schematics would be a tremendous help I could not find them anywhere online. Also is the power supply out I am not sure. Thanks So much
Have you checked Radio Shack? they have a lot of cicuit board stuff for soldering
Posted on May 18, 2007
Why rear windows on 2001 chevy tracker won't work ?
Would seem your into the inner doors & have a partial
grasp on things
Now you fix all door windows one shot
#1 Test all switches,ohm meter unplugged or volt meter with power
#2 Test all motors with battery voltage direct -- DC motor will run either direction-- can't hook up wrong
#3 Window Regulators -you know about them (Unless they are broken-you said they are tight)
#4 Do you have good ground side wiring & battery voltage at all
switches & motors
#5 Last resort--unhook the cables & work on freeing up the
glass & window guides etc then you will have found out if the
regulators are the issue
Aug 16, 2014 | 2001 Chevrolet Tracker
99 aurora, change alt 2 months ago now its over charging 16.7
That's fine this happens i have gotten from 30 minutes to a week out of rebuilt alternators up to 10 years 2 months ago you should have warranty on it contact supplier.
Jan 05, 2011 | 1997 Oldsmobile Aurora
Hi, I have a 1994 dodge ram 2500 cummins turbo, on my way home my speedometer and tachometer stopped working and my volt meter was reading low 10 volts or so with my lights on, two months ago my cruse...
alternator drive belt broken
alternator not charging , voltage regulator failure , battery terminals loose , ground wire loose
have the battery load tested
Nov 11, 2017 | Dodge Ram 2500 Cars & Trucks
Subwoofer popping noise
i had an amp do that a few years ago i did everything it turned out that it was the cdplayer. then agin myfriend had the problem and it was his altonator he had to get a ground loop isolator they are cheap
Feb 02, 2010 | Hifonics Brutus BXi 1206D Car Audio...
HiFonics txi4008 not working, partially lighting up
Sounds like your amp has some power supply compents shorted out. Maybe some of the power mosfets are shorted and your only getting a little bit of power. That why only the H is lighting and as far as the green light, it don't take much for it to turn on. If it was major it would go into protect mode but it is'nt. I repair amps for a living and I'm the cheapest you'll find. But if you know about electronics and think you can take a crack at it, check it out. Becareful you could do more damage. Let me know if your interested. skinnman33@gmail.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Jun 06, 2009 | Hifonics Brutus BXi 1206D Car Audio...
I am ordering 2 pioneer TSW307D4 or D2 is a 2400 watts amp good?
ok theres a amp called slugger they came out about 7-10 years ago its small but very very powerfull i was picking up my 2 15 inch l7 kickers i drove from my house to vegas with no problem about 4 and a half hrs and didnt turn off ,on the other hand i had my fosgate wich i love t1000 wich turned off on me a couple times
Mar 15, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Problem with my amp
then use it as a paperweight...seriously, you prolly blew the jensen speaker, you prolly damaged the amp
May 15, 2008 | Hifonics Titan TXi 6006 Car Audio...
Hifonics 1605d stopped working
the red light blinking because your amplifaier its dead look for the alimentation cabel end replace the calibration protector
Apr 16, 2007 | Hifonics BX1500D Car Audio Amplifier
My amp turns on then off while it slowly blows the fuse out
If I were a guessing man, I'd guess that you had your amp hooked up in a bridged configuration. And also that you connected your two speakers in parallel (plus to plus and minus to minus). And if I were to further guess, I'd guess that you have a blown amp now because of what I mentioned above. Sounds like you need to spend some quality time with your favorite electronic repair shop. Good luck.
Feb 23, 2007 | Hifonics BXI 1606D Car Audio Amplifier
Hifonics BX1500D Car Audio Amplifier Logo
113 people viewed this question
Top Hifonics Car Audio & Video Experts
Mike Duncan
Mike Duncan
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
