Question about RCA M4204 MP3 Player
Radio presets I can preset but how do I switch stations after that?
  • jmk62064 Jan 16, 2009
    I guess I worded that incorrectly. How do I use preset? If I assign a station to #1 and then another to #2, how do I switch?
    Problem Solver:
  • 5 Answers
Go to the radio and then pres the play button and then go down to tuning and the pres the play button till it says manual and then it should let u change the station.
Posted on Jan 15, 2009
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do you assign preselect numbers to radio stations
You can assign radio station presets on your stock VW radio by tuning to the radio station you would like to preset, and then holding down one of the preset number buttons until the radio beeps. You will now be able to access the station by pressing the preset button.
Oct 15, 2013 | Vehicle Parts & Accessories
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
How do i program the radio
Click below for the manual.
manual
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Alpine iDAX305 MP3USB Car Radio Car CD...
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Radio presets?
select radio station then select which number you want to preset station to and press and hold until you hear the unit beep,also preset station will flash once aswell as the beep,station should be preset into your headunit,goodluck.
Nov 29, 2008 | Pioneer Car Audio & Video
RCA M4204  MP3 Player Logo
75 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
