Samsung Projection Color Problem
I have a samsung projection tv and I am having trouble with the color. The picture looks like I am looking at a 3D movie without 3D glasses. even when i click on the menu button for the tv the color there is messed up also. The red,blue and green lines don't seem to be matching. I tried the convergence option in the menu but none of the plus signs will move to line up. Is there an easy solution? How much would this cost to fix if fixable.
  • 100 Answers
Its the problem of stk ic on the main board and needs replace ment. just get it from radioshack websites and replace the ic to solve the problem.
Posted on Dec 29, 2008
  • 19,396 Answers
That means that the convergence is gone, when that happens there is often a fault concerning convergence board and convergence ICs. Better calling a technician to fix this.
I have a Samsung floor model TV model number HCP4363WX/XAC I think it's the color aliment but picture looks fuzzy it kinda looks like it 3D how do I fix this issue.
That tv is a rear projection tv. It uses 3 CRT tubes that are Blue, Red, and Green and converges the pictures on top of each other. The convergence chip needs to be replaced. Samsung Akai Projection TV Repair Kit for one or more of the following...
You can order the repair kit from here and it comes with step by step instructions for the repair. I have personally used them before with a lot of success.
Jan 25, 2017 | Samsung Televison & Video
How do i set the color for picture
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com Common Problem #1) Convergence has gone out Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Apr 24, 2013 | Mitsubishi WD-62525 62" Rear Projection...
DO SAMSUNG HC-P4741W TVS HAVE A TROUBLE CODE LIGHT?
if color is skewed or looks 3d its a convergence problem--select that in main menu and try to adjust--if will not adjust it needs the chips for that replaced.
Jun 07, 2012 | Samsung HC-P4741W 47" Rear Projection...
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
Tv plays but picture is orange redish like tried to ajust color and tint still the same
Tv have a problems known as a picture convergence problems,it is dead.If the tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,then the tv convergence board it is dead,the tv convergence board must have replaced like 2 STK convergence ICS and some or all of resistors replaced too.To fixed the tv convergence board to solved tv convergence pictures problems.The tvs Shops will cost u like $300-350 for parts and lobors.
Jul 27, 2011 | Samsung PCL542R 54" Rear Projection...
I had a 3d effect in my tv and a repair man came out to fix it. but my tv still has color issues. what settings can I use to correct the color> its a samsung (hcn4226w)
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Feb 26, 2011 | Samsung HCN4226W 42" Rear Projection...
Picture has a problem lost a lot of the color
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Picture is not showing correctly. Color seems like it is going out. For example the color green does not show up as green.
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The Akai/Samsung DLP tv used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Samsung PCL541R 54" Rear Projection...
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Color convergence and color looks 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 24, 2010 | Sony KP43T75GRAY 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
