I have a Philips TV and the on/off power button no longer works. I can turn the tv on/off only via the remote control. Any idea how to fix the on/off button?
    Genius:
  • 2,920 Answers
Youd have to take the tv apart and if the button is there glue it back into place,,,use super glue it works best
Posted on Dec 29, 2008
What is causing the volume to to change on its own?
This is a known issue for this model, and you need to ask for a service intervention via your dealer or Philips (http://www.support.philips.com/support/catalog_selector.jsp) to repair it.
Nov 22, 2015 | Philips Televison & Video
Need information on a philips t.v. model 32PT6441/37
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 12, 2008 | Televison & Video
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
Can I change my Philips DVP3950 to region-free?
Before you begin please ensure you have connected your DVD player to your TV and both have the power turned on. Once you have connected your TV please follow the instructions below using the remote control.
Select SETUP then press OK (via the DVD remote control)
Using the arrow down button highlight PREFERENCE
Press NEXT, PREVIOUS, NEXT, PREVIOUS (the >l, l<, >l, l< buttons in the bottom of the remote control ).
Your current region should show on the TV screen
Using the arrow down button select region code 0
Press OK
Press the 'HOME' button
You have now completed this process. Enjoy! (from multi-region.net) Also works for DVP3800. The remote control has no numbers on model DVP3950
Dec 23, 2012 | Philips dvp-3960 region code free dvd...
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control
Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
Press the "TV" button on the remote to program the Philips remote to your television set
Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Remote control stopped working
Hey. I paid the $20 for the expert advice and (I feel such a fool) I just had to unplug the tv and plug it in again for everything to work!
Martin000
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Sep 19, 2006 | Philips 28PW6506 28" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
