Question about GE GSH25JFR Side by Side Refrigerator
Ice and water dispenser not working
Ge side by side gsh25jfr, ice and water dispenser not working. Changed the control; board, like tech said. Water surts out intermitantly and causes door light to dim with popping sound that last for mins to hours. Noise stopped most of the time with pressing light on outside dispenser.
  • Anonymous Mar 15, 2014
    I have the new part. I was told to take the trim around the dispenser off using a putty knife but it just doesn't pop off. I have looked at you tube videos but none of the things that they do seems to work on my unit. How is that trim attached.
    Novelist:
  • 114 Answers
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
Posted on Apr 27, 2007
Replaced water filter and still won't produce water
If the ice maker works and the dispenser does not the most likely cause will be the=> WR57X10032 Dual Water Control Valve
In rare cases the water will freeze in your water tank or iside of the freezer door but if this has not happened before and you are seeing no extreem cold temps in lower half of refrigerator section where the water tank or coil of water line that cools the water before it reaches dispenser you will possibly resolve this problem by replacing the dual water control valve. Let me know should you have questions, Thanks Sea Breeze
Feb 27, 2013 | GE GSH25JFR Side by Side Refrigerator
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
The unit stopped dispensing water, makes clicking nose
If you would like to do this yourself and save the fee of a service tech I ill tell you the motherboard and compressor start components have been affected. Just replacing the board is not always the answer. These refrigerators are sensitive to electrical surge, fan failure, compressor start component failure and eliminating the cause is the best and less expensive way to approach this, I will return later and discuss parts and I do need you to confirm your model is the GSH25JFR, Thanks, Sea Breeze
Feb 08, 2010 | GE GSH25JFR Side by Side Refrigerator
Our water dispenser on our side by side is not working. we have changed the filter and it's still not working.
We researched this problem for our GE, & it's common on the model GSH25JFR. When the insulation for the door was being applied they did not tape down the tubing for the water. The thicker insulation pushes the tube right up against the ice maker causing it to freeze. You'll need to get a new left side door from GE to solve the problem.
Jan 10, 2010 | GE GSH25JFR Side by Side Refrigerator
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Water is not dispensing. Can hear water flowing. Not coming out.
Watre control valves have 2 sides one side for the ice maker and the other for the water didpenser. It is possible that the side for your dispenser is defefective and the complete valve will need replaced. The part number for yours is WR57X10032 and can be found here
http://servicepartstec.blogspot.com/ Just enter the number and click find it. Thanks, Sea Breeze
Aug 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Water not dispensing ,side by side gsh25sgpa
make sure the water line is not kinked behind the refridgerator.
Jul 04, 2009 | GE GSH25JFR Side by Side Refrigerator
Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Apr 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX25JRYFAA SIDE BY SIDE GE REFRIGERATOR
try taking off the dispenser front and check the "switch " controlling water /ice. its a micro switch your connecting with as you change from one to the other{ice to water) im assuming that the switch is not being activated. plungers get stuck switch gets old
Mar 11, 2008 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
252 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
