Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Ignition failure. Relatively new furnace - under 5 years old.
Replacement unit. Apparently the igniter is not working. Is this a replacement item for a non pro, but relatively savvy handyman?
  • 61 Answers
You can replace a hot surface ignitor if you are careful not to touch the silicon surface. The oil from your hand may cause the ignitor to fail. make sure to turn off electric supply before attempting. You will probably need an OEM (from a coleman dealer) ignitor.
Usually best to bring the old one with you to make sure you get the right one with the right wire terminals. Or you can wire nut a new one to the old terminals. Could also be a dirty flame sense rod.
Hope this helps.
Posted on Dec 31, 2008
Home Heating Repair - How to Change Your Gas Furnace Igniter
You have run all the tests and they all point to your igniter being bad in your gas furnace.
Your purge blower runs, the power comes on to the igniter, but you get no glow from that little wonder. How can it be changed?
Changing the igniter on your gas furnace really is not all that hard. But it may require a bit of patience and some tools that can get into some very tight quarters. Some furnace manufacturers have design their units to make this job very easy. Some other engineers obviously have never got away from their desk and picked up a screw driver. Hopefully you are lucky enough to have one of the easy ones.
The higher the efficiency of your furnace the harder this job will be. Usually the 90+ furnaces will have the burner compartment sealed. You will have to get the covers off of the burner compartment to get to the igniter. On the 80%er’s the igniter will usually be somewhere on the burner nearest the center of all the burners. Make sure that you remove all power to your furnace before you attempt to remove the igniter. It runs on 110V power and will give you a good jolt if you touch it with power going to it.
Once you have located the igniter, you will need to find the screw or screws that hold the igniter in place. Remove or in some cases just loosen the screw and remove the igniter. Take careful note of the location and position of the old igniter so that you can reinstall the new one in the exact position as the old one. In most cases the wiring will just be a Molex plug that you can just unplug the old igniter and then plug your new igniter back into it.
Carefully position the new igniter into the same location and tighten the screw(s) that hold it in place. Plug the new igniter into the plug and replace the covers on the burner compartment if there is one.
Now you can turn the power back on to your furnace and try for ignition. Hopefully you get the glow and ultimately fire in from the burners. This will give you heat and make everyone happy!
on Dec 06, 2009 | Heating & Cooling
Ignition failure.
if furnace fires up then immediatly shuts off check the flame sensor. make sure it is sitting far enough inside the burner box and has proper continuity. if ur getting ignition failure without having furnace fire up, check proper voltage to hot surface igniter, continuity within igniter
Dec 05, 2013 | Heating & Cooling
6 year old colman furnace codes 1 blink ignition failure. Turn heater off at thermostat it cycles and heatsd house restarts a few times. alot of clicking noises and codes again a few cycles later. works...
I had the exact same issue and replaced the control circuit board, igniter, flame sensor, and thermostat just to discover the real problem was a rusted out Roof Jack. (The exhaust pipe that goes through the roof. The inner fresh air pipe was rotted out so the furnace was sucking exhaust gases in which would not support combustion. Have your's checked.
Oct 24, 2013 | Coleman Propane Forced Air Heater...
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
16 year old Heil 75K btu furnace, some times does not ignite.
recommend getting a carbon monoxide indictor or having some one test it. with it being over 15 yrs old if checks good replace ignitor assy should fix it ok
Dec 14, 2008 | Cross Furnace Draft Inducer Blower 115...
Thermostat wont turn on heater Robert Shaw 9600 prog.
I have a thermostat 9600 Robertshaw and I have to use the trip switch to start my furnace. Then it reaches the temperature and sometimes it will kick in by itself but majority of the time I have to trip it. I have changed the batteries cleaned the thermostat,and reset it. Is it time for a new thermostat and can I replace it myself. Thanks
Nov 06, 2008 | Heating & Cooling
Amana Air Command 80, 20 years old. Electronic ignition. Furnace does not start. Good power to furnace. Themostat properly set. Where do I start looking? Bob
Hello Bob,
Welcome to fixya,
You said, Amana Air Command 80, 20 years old.
Thermostat properly set.
Sounds like you possibly have one or more bad jets if the unit is a gas furnace!
Let me know how it goes.
WOW, listen to this story!
I understand you are looking for the solution to fix your furnace your self.
But I want to tell you my story about my smart wife and our furnace.
When we moved into this house the furnace was 20 years old and she suggested that we put a new one that it will save us money.
I laughed at her and replied if it's not broken why fix it!
Six years later it finally broke down and I replaced the whole furnace and central air unit with a new one.
Our utility bill went down $100 dollars a month!
That's $7200. that I lost over 6 years due to not respecting my wife's power of reasoning!
If you can afford it or can get financing replace any unit 20 years old and it will pay for it self.
Can you imaging $1200. a year for 20 years is $24,000 dollars I'm saving with a new and efficient unit.
Do the math!!!!!!!!!
Thank You,
Huuum, Hope I gave you some good fatherly advice.
Please remember to leave a rating
Oct 12, 2008 | Amana Heating & Cooling
Ignition failure after three attempts then sits for an hour.
try cleaning the burners and or adjust the distance the igniter is from the actual burner .
Oct 01, 2008 | Goodman GDS80904BNA Open Flame Heater
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Heating & Cooling Logo
204 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
