Question about Saws
My DREMEL 1680 Variable speed 16" scroll saw will not turn on.
The saw I have had for 5 years and is my second scroll saw. Today after using it just 3 days ago I attempted to use it and it would not turn on. The light comes on so I know it has power. I pulled each of the brishes out and they are still almost new with well over 1 1/2 inch on material left.
I have attempted to reset the reset button but it seems to be in the up position and I cannot get it to click or move.
Do you have any suggestions before I have to take it to a repair centre.
As a result of the power being on to the attached light I knew it was not a power source problem so I took the fuse area cover off(with the machine unplugged) and saw there were no loose connections in that area. I then removed the front control area where the two swithes for the saw and light were. I took off the two wires on the saw switch and then plugged the saw in and jumped the two wires together. The saw worked!!!!!!. I then changed the light switch over to the saw switch location and the switch works . It appears it was a faulty switch. Today I will call the Dremel 1-800- number and order a new switch.
Bernie Lutes
Posted on Dec 29, 2008
Manual forBaumr-AG scroll saw
Found a direct link from the edisons website. First is the link to your scroll saw and second is a direct link to the manual:
https://www.edisons.com.au/16-variable-speed-scroll-saw-ss16/#easytabs
https://www.datastreamserver.com/manuals/TOLSCSBMRAS16-manual.pdf
Jan 17, 2018 | Saws
Dremel troubleshooting
If you've allowed it to overheat, you'll have to wait before you can turn it on.
Aug 05, 2014 | Dremel 300228 300 Series Variable Speed...
Dremel 1800 scroll saw manual
Here is a list of what you can get. If it is not listed there then there is a spot at the bottom of the page to request a manual.
Dremel manuals
Aug 22, 2012 | Dremel 1800-01 Scroll Station 18" Variable...
I have a 1680 scrollsaw and no manual. Where is oiling required?
Lubrication
ARM BEARINGS
Lubricate the arm bearings with oil after 10 hours of use.
Re-oil after every 50 hours of use or whenever there is a
squeak coming from the bearings.
TO LUBRICATE
1. Turn saw on its side (Fig. 18).
2. Remove rubber plug to expose bronze bearing.
3. Squirt a generous amount of SAE 20 oil around the shaft
end and bronze bearing.
4. Let the oil soak in overnight in this condition.
5. Next day repeat the above procedure for the opposite
side of the saw.
You can get the manual on the link below. scrool down to product details to get it.
http://www.amazon.com/Dremel-1680-6-Horsepower-Benchtop-Variable/dp/B0000302YQ
Good Luck
Dec 04, 2010 | Dremel Owner Operator Manuals Moto Shop...
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Dremel scroll saw 1672 16'' two speed scroll saw slow motor
Go to Dremel.com or call toll free1-800-437-3635 and tech service might be able to get you a schematic and wiring diagram. It does sound as though the switch is either wired incorrectly or put in upside down. If I have helped you on this would you please take the time to rate me accordingly and Thank you
Apr 03, 2009 | Saws
Dremel Scroll Station 1800
You need to replace the variable speed control switch. Other than that, your not doing anything wrong. Have fun
Feb 04, 2008 | Dremel 1800-01 Scroll Station 18" Variable...
Saws Logo
751 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
