Question about Linksys Wireless-G Broadband Router
I'm having trouble installing my Linksys A+G Broadband Router to my computer, which runs Windows Vista. All connections are correct however the router is not recognized.
  • Anonymous Dec 31, 2008
    I cant get internet on my labtop and have have tried 2 different techniques can anyone give me on more
  • Prasanth Vignesh May 11, 2010
    Can be a bit more precise when u say its not being recognized. Please follow the below steps and revert back with results so that i can help u: 1.Look at the router there should be four lights generally (which will have either numbers or LAN1,LAN 2,etc,etc).See if the light of the port u have connected to is lightup,if so proceed to step 3. 2.Click on Start>>control panel>>Network and sharing centre(or Network and Internet) and select the "Manage network connections" which would be on the left pane of the window.Right click on Local area connection and select "Enable" if disabled. 3.Now clik on start and in the search box type "cmd" and you will see the command prompt appear as a result above, right click on it and select "Run as administrator" now in the black window type "ipconfig" and hit enter.If u see something like 192.168.1.X, then ur router is working fine.Connect ur modem directly to your computer and check if its working,please try these steps and revert back with results :)
  • Linksys Master
  • 8,404 Answers
Please give Network Magic a try. I Professional grade network management tool for the home, it will help you to resolfe all network issues. Get it here: http://www.purenetworks.com/nmlp/home-networking.php?gclid=CPua-J-J1J4CFVw55QodUi_Nrw&src=google&kw=network+magic+download
Posted on Dec 13, 2009
How do I set up my router with out the disc? It won't run because it is Windows 95 not vista
if you connect the computer to the modem, does it work ?
If that works then the modem is working working properly.
now connect the modem and the computer to the router. open the set up page of the router.
here you can change the settings of the router.
You don't need CD to set up router
Click here to know more about how to set up router.
Jan 09, 2010 | Linksys Wireless-G Broadband Router
I installed a linksys wireless-G Broadband Router and my laptop does not get a signal. Help please
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 26, 2009 | Linksys Wireless-G Broadband Router
Wifi getting connected with new linksys
You need to call Linksys again for them to help you setup the other computer. For the none-working computer, you don't need to run the setup CD for the router. All you need to do is connect to wireless network like what you did on the working laptop.
Jun 26, 2009 | Linksys Wireless-G Broadband Router
Trying to install Linksys wrt54gx2 srx200 on my vista computer
who is your broadband provider? Is this cable or DSL connection? Setting up the router is done via http://192.168.1.1. Leave username blank, password is admin. If you have Cable ISP, then make sure you have "Automatic Configuration-DHCP" selected and MAC address Clone is enabled on Setup > MAC address Clone (click Clone, and Apply). If it's a DSL connection and your broadband provider gave you a username and password, select "PPPoE" for Internet Connecton Type, and enter in your DSL username and password. Next verify if your modem is communicating with the router by going to the Status page and by verifying that you have an Internet IP address. If none, wait for a few minutes and power cycle your modem and router.
Dec 11, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys Wireless-G Broadband Router Nonfunctional
go on to the LINKSYS website and see if your rounter works with vista if not then they may have a driver for it
Nov 19, 2008 | Linksys Wireless-B Broadband Router Retail...
Wireless problems with windows vista
You just need to remove the preferred networks on your vista, follow this.
Right click the wireless icon>network and sharing center>manage wireless network>remove all preferred networks.click OK.
Then connect again to your network that should solve it.
Jun 13, 2008 | Linksys Wireless-G Broadband Router
I want fast help..how to get connection between linksys router and aztech modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
138 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
