Question about Memorex MVR4052 VHS VCR
How Do I use timed recording?
How do I use timed recording. I've tried and tried. I have a cable box so I'm assuming its going to be a little harder to figure out but can someone help me?? Thanks
    Novelist:
    Champion:
  • 254 Answers
Is this a problem of the VCR not doing a timed record at all, or of it recording only snow (no signal) or perhaps the wrong channel? If the first, then it would point to incorrect setup of the timed record session or that the clock time & date settings are incorrect... the VCR setup stuff. Also, once the timed recording is setup, there is often one additional button to push to actually ready the VCR. Older VCRs, were put into the timed mode by power off. If VCR isn't recording anything (it is coming on to record, but no signal), then it has to do with hookup of the VCR. Depending on your cable system, the VCR can only record the channel the cable box is tuned to. Again, depending on the system, the VCR needs to be cabled in between the cable box and your TV (cable box RF out to VCR RF in, VCR RF out to TV RF in) RF=ant. Exact cabling will vary.
Posted on Apr 27, 2007
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
My hdmi connection for dvd & cable have both stopped working. The receiver is flashing
Unless you've been pulling it in and out, it shouldn't go bad. I assume you've checked to be sure it's properly connected.
HDMI cables should cost less than $20. If you were talked into a $100 cable, you were taken advantage of.
HDMI has a function called HDCP. The TV source and TV have a conversation over it to make sure that only an approved device (your TV) is connected to the cable. This is for copyright protection reasons.
Have you recently connected a new source (cable box, DVD player, whatever)?
Your problem can be in the TV, the cable or the source.
Try substituting for each to determine what's failed.
If you have your TV now hooked-up with component, you may have discovered that there's little or no difference in the picture
Aug 04, 2012 | Sherwood NEWCASTLE R-774 7.1 RECEIVER WITH...
I have a vcr/dvd combo. Can't record on it, was told that was because the cable here is digital. Is there some sort of adapter I can attach to enable my vcr to work again?
The only way to get your cable company's digital cable into the VCR is to provide a separate cable TV converter box for it.
This will be "an additional outlet" as far as the cable company is concerned - which means you'll pay extra for it. The other problem will be that you will have to locate the VCR cable converter away from the one used to send a program to the TV. This is because there is a very good chance that when you aim the remote to change the channel on the TV's cable converter - it will also try to change the VCR cable converter box.
If however, you have HD service on your TV you should not get an HD box for the VCR - unless there are stations that only exist on the HD converter box. This is because your VCR (like all the others in the world) are only capable of recording the old, analog "SD" or standard definition video signals. If you decide to go the route of an HD and an SD converter setup, you may not have a problem with one remote controlling both converters. Ask the installer (or test yourself) before setting it all up and merely assuming it will work as you expect.
If you end up with two identical converter boxes, you're going to need to either separate them so that the remote will not operate both at the same time. If this isn't doable, you might consider placing electrical tape or similar to block the remote signals from reaching the the VCR converter, and use the channel up / down controls on the converter box itself to tune instead. Since the VCR will only record what is sent to it - you'll have to make sure the converter box is not only on, but tuned to the correct channel before each time you want to record something. This brings up the last caveat, you'll need to set your VCR channel to match the output of the converter box (usually ch 3 or ch 4) and record only that channel. You could simply connect the converter audio and video output to the VCR's audio and video input instead. If you do this, make sure the VCR is programmed to record only the audio and video input ("A / V") instead of a channel.
This can sound a little complex - and it is to some people, but with a little work and some time, you'll be able to do this fairly easily. I wish there was an easier way to do this - but not yet with cable companies so far. The satellite providers are ahead on this with "multi-room viewing" service. Something to think about the next time your cable company announces a rate hike.
I hope this was helpful and good luck!
Sep 21, 2011 | Televison & Video
My problem is that i have a 56" philips with hdmi etc... i have my dvd recorder plugged in via audio video cable .... i have my cable coming thru hdmi... i cant get my recoreder to record whats...
Hello rpgscope,
I am assuming both your dvd recorder and cable is plugged into your tv? Conncet a composite cable (rca cable or aka red, white, and yellow cable) from cable box OUT to dvd recorder IN. That should fix the problem. I mention composite cable but if you another slot for av then go ahead and use that. Make sure you have AV connected from dvd recorder OUT to the tv IN. Also the cable box should be HDMI OUT to tv IN. If you have it connected like this, it should work. Hope this helps.
- Joe
Aug 30, 2011 | Toshiba Televison & Video
RECORD BLOCKING SIGNALS DETECTED APPEARING ON SCREEN WHENEVER I TRY AND RECORD WITH RH7521W
I assume you are trying to record from a VCR tape to a dvd? It could be the copyright protection causing this issue. A little more information would be a great help. What are you trying to record? VCR Tapes. Are these home movies or are they retail movies. Macrovision prevents recording. If you are trying to record a television show, it could be the digital rights protection. do you have it connected to satellite or cable.
Jul 19, 2011 | LG RC897T DVD Recorder/VCR Combo
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
I cannot get vcr to record channels timer goes on and on playback blue screen
I assume it plays back a pre-recorded film with no problem? Check your antenna is connected to the input of the VCR or your cable box. If you have a cable box connected via a scart connector, then select AV channel on the VCR & select the programme from the cable box. If you are using the antenna the go into the set up menu & retune the VCR into your incoming channels & ensure the flylead from the output of the VCR (at the rear of the video next to where the antenna cable is positioned) is connected to the input antenna socket of the TV.
Jul 28, 2009 | RCA Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Can't find source
The very same problem i am having, If you find out please e-mail me @ ulcard35@yahoo.com In subject please type DVD PLAYER..Thank you for your help
Feb 20, 2008 | TruTech T650-DR DVD Recorder
Not capable of recording
A tuner converts broadcast (including cable) signals to composite video that the TV uses. Now that the broadcasters are going digital, equipment sans tuners like yours are on the market. You can either return the unit for the older style or you can buy a converter box for your cable. The Fed Gov is going to be offering 2 $40 vouchers per household to help you with the change over but it hasn't commenced yet.
Dec 31, 2007 | Computers & Internet
Memorex MVR4052 VHS VCR Logo
217 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
