Question about Broan-NuTone Intermediate Whispaire WA6542SS Stainless Steel Kitchen Hood
As fan picks up speed it seems to vibrate
When it reaches top speed it goes away when you lower the speed it comes back
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Vehicle vibrates at certain speed
Hi Anonymous
I trust you are well
With limited information I can suggest the easiest solution.
If you have a vibration at a certain speed and it persists for a while and then goes away when you reach a highr speed it might well be that you wheel alighnment is out. Try having your wheel alighnment checked at a tyre dealer.
Hope this helps
Aug 15, 2014 | Cars & Trucks
Vibration in driveline in 4wd at 40 mph+
Have the u joints checked on the drive shaft that goes from the front diff to the transfer case one or more my be seized or loose .
Jan 29, 2014 | 1998 GMC Sierra
Vibration at 80-100k in a 4x4 Ford 350 diesel superduty
Sounds like you need to get your tyres balanced. If the vibration is when you don't touch the brakes only between the 80-100.
If its when you touch the brake pedal and the vibration occures, your disc brakes are warped, either machining or replacement.
Jan 30, 2013 | Cars & Trucks
1997 ford explorer overheating but no gurgling and cools back down when heater is turned on . not loosing any coolant. does not seem to do it at idle but as soon as you start moving it goes up and when it...
Make sure the cooling fans are working when the engine reaches above normal temp,if they are not ,turn the ac on,and see if the cooling fans come on,if so,replace the coolant temp sensor,if it has a clutch fan,then replace it,for it is not staying engaged ,and is not turning fast enough to cool the radiator.
Nov 29, 2009 | 1997 Ford Explorer AWD
Vibration through the car Transmission-motor Linkage?
Check to make sure both headlights are tight,,,when it rattles at idle go feel the headlight and hold it and see if the noise and vibration goes away,sometimes the headlight has too much clearance and causes a massive vibration,,if thats not it try...loosening all the motor mounts and rock the car back and forth and them retighten them,it reseetles the mounts and sometimes fixes the issue,,also check the lower engine and trans mounts for wear.
Oct 30, 2009 | Saturn SW2 Cars & Trucks
Vibration at speeds of 45-55mph
Check your drive shaft u-joints..Number one cause.Have a great night!!!
Apr 03, 2009 | 1995 Dodge Dakota
Broan-NuTone Intermediate Whispaire  WA6542SS Stainless Steel Kitchen Hood Logo
160 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
