Question about Zebra Stripe S600 Thermal Label Printer
Printing fade at the midle of the page
Hi there, I was making some testes printing labels with my Zebra S600 and everything was going just fine. But, when I finaly got the label printing out just the way I need it, the printing started to fade out in the midle label. I'm using the same format parameters for all the tre labels (in a line) the top and the bottom label are printing just fine, but the midle label fades (like, you can't even read it). I've cheked the ribbon and it's ok. Does any one knows what could be happening?? I would really appreciate some help on this one... Tanks, Lucin
    Sniper:
  • 58 Answers
Build up on the printhead, printhead pressure, or worn platen roller...
Posted on Jul 29, 2007
SOURCE:
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
Hi, On a Zebra S600 printer... How to change setup for print method (actually it showing up direct thermal) and we would like to change the print method to (Thermal trans). Thanks! Pierre Tardif
The easiest way may be to change your printing preferences at the driver level. We use Seagull Scientific Drivers (They are free to download).
If you use the Seagull Driver go to your Printers Folder, "Right Click" your printer and go to Properties
Then Go to the General Tab then Printing Preferences then Stock Tab then Print Method. Click on the Down Arrow and change to THERMAL TRANSFER.
If your using a label printing package make sure your settings are for Thermal Transfer since they can override default printer settings.
Good Luck
Mikeo@acebarcode.com
Feb 16, 2011 | Zebra Stripe S600 Thermal Label Printer
I have installed (hardware + driver) a stripe s600 via COM1 on my desktop; how can i get a test page? i does not work from the test page @ printer properties.
You should be able to print a test page from Windows.
First make sure the device itself can print by holding down CANCEL while you power it up. Release the button when the CALIBRATE light goes off. This should print out a config label.
Here's the manual: http://tinyurl.com/yb2rpd4
I would check all the connections, download the latest drivers from the Zebra website (not the ones on the disc) and reinstall.
Hope this is helpful for you!
If so, please leave a rating!
Feb 28, 2010 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Printing
You have to program the tearoff.
See the manual or use a windows driver to end the value to your printer
Aug 24, 2009 | Office Equipment & Supplies
Zebra S600, Recieves data, but does not print
Go into the printer driver and select print a test page, does it print out?
If so then try printing from your label software, it should work, if not then it is your software that is at fault.
If the test page does not print out then check all the settings in the print driver, so they are the same as the physical label.
If non of this helps then go to www.lancerlabels.co.uk and do a live chat to Michael.
Feb 17, 2009 | Zebra Stripe S600 Thermal Label Printer
Zebra S600 Thermal Ribbon Ripping after printing
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
Sep 23, 2008 | Zebra Stripe S600 Thermal Label Printer
Not printing the correct text / picture
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Sep 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Not printing
this problem will address on label and ribbon issue. you must establish your printer set-up first, meaning see to it that the label and ribbon was correctly loaded, if still problem occur try using manual calibration you can see how to do at the manuals you have..
Jul 29, 2008 | Zebra Stripe S600 Thermal Label Printer
Labels print out of position
Try cleaning the media and ribbon sensor you can open it and try clean it, it possible that there's a lot of dust or even small particles at the sensor path..
Jun 05, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
426 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
