Question about Olympus FE-230 Digital Camera
Write protect i was trying to copy photos from my camera to my pc. my camera stopped taking photos afterwards and a blue screen says "write protect"
    President:
  • 919 Answers
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Posted on Dec 29, 2008
My memory card was not in my Panasonic Lumix digital camera when I shot some photos. It said that it is stored in the buit -in memory . a- how do I retrieve the photos to store on my computer? b-how...
In the menu there is an entry for "copy" which gives you the option to copy the internal memory to a memory card for easy downloading. Then, when the pics are safely on the card, take it out of the camera and go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
Nov 04, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a vivitar vivicam,i havent used it in a
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 15, 2010 | Vivitar ViviCam 8025 Digital Camera
I have a vivitar vivicam,i havent used it in a while. I just tried to take pictures and it says card protected. It lets me look at allthe features and my old photos but not take new ones. When i try CARD...
There is a little, and I mean little, lever on the top left, and if it's in a Locked positions...it is "protected"...move the lever to the Unlocked position and you shouldn't have any problem.
Mar 28, 2010 | Vivitar ViviCam 8025 Digital Camera
Small scratch on front lens causing shadow on some photos, in particular on clear blue sky when a small area in the photo appears slightly deeper blue than the rest.
You have only two fix options:-
1. Get the front lens element replaced by Panasonic. This will be fairly expensive. Afterwards, buy and fit a skylight filter to protect the lens.
2. Buy a skylight filter to protect the front of the lens from further damage and use photo processing software to retouch the affected images. This won't necessarily cost much, but will be a real pain to have to do all the time.
Whatever you do, do not attempt to polish out the scratch as this will destroy the lens coatings and will also reshape the lens slightly ruining it's optical qualities.
Feb 03, 2010 | Panasonic Lumix DMC-FZ18K Digital Camera
Sony cybershot DSC-T2 has a blue screen on playback
Dont worry, you can recover photos from camera with photo recovery software, recommended asoftech photo recovery as it helped me before. Download the software from
Camera Picture Recovery Software
Here's a good tutorial you can follow
Restore images from Camera
Dec 26, 2008 | Sony Cyber-shot DSC-T2 Digital Camera
Cant take photos as it says the card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Mar 20, 2008 | Nikon Coolpix 4100 Digital Camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 17, 2008 | Olympus FE-280 Digital Camera
Write protect
just open the card cover and press quick view and ok at the same time, and reset the camera. if that don´t solve it may need to replace the mainboard
Feb 11, 2007 | Olympus Camedia C-310 Zoom Digital Camera
Write protect card
thos pictures are lost... u ken fix the problem by format...menu- setup- format...they are problems with the pictures because the camera was shaken allot...dont worry this will do it... or u ken get a card reader to get thos photos back, but the format is required
Sep 22, 2006 | Olympus Stylus 700 / 700 Digital Camera
Olympus FE-230 Digital Camera Logo
102 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
