Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How do I get to the hoover steam vac standpipe seal?
I can see from the top when I take the thing apart that the standpipe seal is dislodged, but how do I get to it? I have taken the entire thing apart and still can't get underneath it. It appears that there is a portion of the bottom that can pop out (no screws), but it won't budge. Help!
  • Vacuum Medic
    Vacuum Medic Oct 09, 2012
    I dont know what you mean by standpipe... Are you talking about the tall tube where air flows from the recovery tank to the fans? Help me to help you! :)
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
SOURCE: Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Posted on Jan 13, 2009
  • 909 Answers
SOURCE: Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
Posted on May 13, 2009
VacuumRepair
  • 438 Answers
SOURCE: My Hoover Steam Vac Spin Scrub aw/ Clean Surge
Greetings,
A few more things that you can try on your SteamVac. First remove the dirty water solution tank from the machine completely. You should see where the solution tank was just sitting, a plastic casing with a whole in it. This is actually where the suction from the motor goes into. Turn the machine on and feel the hole there for any suction coming out. Did you feel suction coming from the hole? If yes, then your issue is going to be something with the dirty solution tank, because without the tank it's sucking fine. If you didn't feel any suction from this hole, it may indicate that there is something more serious that needs to be taken care of.
One other place you may look on your machine (as long as the upholstery hose for stairs and furniture is already attached to the machine, and you don't have to hook anything up to the dirty water tank to use the attachments) while the dirty solution tank is out of it, is where the attachment hose makes connection with the vacuum. If you recline the handle down while you have the dirty water tank out, look in the back of the handle housing for a hose that enters the housing 3/4 down the housing. Now follow the hose on the inside of the handle not the outside, follow it up to the point where it goes into the neck, near where the suction hole is. Right at the end of the hose, right before the hose cuff, is this ripped, or damaged here?
Please feel free to request a clarification to this repair if you still need addtional help. If you can leave me the model number exactly that would help me help you, lol. I hope that this was helpful to you. If this was helpful to you, may you please click the helpful Thumbs Up Icon in the lower right hand corner of this repair?
Thank you so much,
Chris J.
Posted on Mar 21, 2010
  • 190 Answers
SOURCE: hoover steam vac has no suction
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Make sure the tank lid is aligned to the recovery tank to seal, and assure the square panel is in place on the front of the recovery tank that connects the vacuum of the tank to the clear nozzle plate.
Posted on Mar 23, 2010
How do we get at the drive belt? The cover seems to be sealed.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
Jun 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I own a hoover steam vac model # F5915900 inside the recovery tank the seal broke. Where can I buy a new rubber seal?
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
Mar 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover steam vac leak from the bottom when tank has water in it when not running but tank is not leaking
The tank is not sealing to the black rubber ring seal on the lower handle. make sure this seal is not displaced.
Nov 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Mar 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Jun 23, 2008 | Karcher DE4002 Steam Vacuum
Cleaning steam vac
There are screws on the bottom to remove, then near the back on each side, the is a catch to release. Before you turn it over, there is a screw where the water intake is near the top to remove.
Feb 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
140 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
