Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Hooking up my honeywell he360 humidifier on my carrier furnace
  • AgentW Jan 11, 2009
    I am attempting to wire my HE360A Humidifier to a Carrier 58MXA funace. The Furnace has a HUM connector that will have 24 VAC when humidifier demand needed (presumably, though I have not verified this with a meter).
    How is this wired into the humidifier and humidistat; it has two yellow wires (which I believe are only looking cor continuity - Humidistat contacts closed...etc) and two red wires which as stated on a warning label, supply 24 VAC.
    Please advise.
  • Anonymous Mar 03, 2009
    Same Problem
  • 478 Answers
How can I help?
Posted on Mar 12, 2009
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Fan and water run continuously on he360
I'm not sure what wiring option did you use, but looks like you did not include pressure or sail switches... When the furnace blower/fan is off it should open the 24volt circuit and close the water valve (normally close) and turn off the fan. If you can post more wiring details maybe pictures or hand sketch I'm sure problem can be fixed in the few minutes.
I hooked the humidifer up and water keeps running it dose not stop when furnace stops. What might be wrong?
Hello, this could be tw o different things. when you install a humidifier you need a means of turning it on and off with the furnaces blower motor, this is done by either a sail switch, current sensing relay, or by the transformer being hooked up directly to the furnaces control board. if you do not have one of those three than the humidifier will run continuously untill u manually turn it off at the humidistat. If you have one of those three installed already than the solenoid valve is stuck and must be replaced.
Feb 08, 2011 | Honeywell HE220A1019 Whole House...
I hooked up a honeywell HE220A by-pass humidifier and the water is constantly running with the furnace on or off. I wired it the same way the diagram said using the transformer that plugs into an outlet,...
If you have very old furnace, does it have a blower with a belt. If it does it should only have 2 wires going to blower. If it has 2 you should be able to use the transformer you have plugged into wall and splice into 2 wires going to blower. If you have more than 2 wires to blower, you will need to find out which one is used for heat plus use the white one. If you have a voltage sensor you should be able to find it easily.
Jan 24, 2011 | Honeywell HE220A1019 Whole House...
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Mar 11, 2009 | Honeywell HE220A1019 Whole House...
How do i hook up my humidifier using a seperate transformer
If you chose to install this with an auxilary transformer. Turn the main power off to the furnace. Mount the transformer on the handi box to the furnace or inside the furnace cabinet. Wire the primary wires from the transformer to the main power coming into the furnace. Connect black to black and white to white. Wire the secondary side of the transformer in "series" with a #50 relay, the humidistat, the solenoid valve and back to the transformer. Determine which wire powers the blower motor for the heating speed. Clamp the #50 relay to the wire.
Good luck
HVAC Teacher
Feb 22, 2009 | Honeywell HE260A1010 Whole House...
How does transformer hook up
if you just replace the unit and it is working, no your do not need the tranformer. The unit is getting power from the furnace. For reference though. The black and white wires are your 120 volts. Black hot, white common. the 2 screws are your 24 volts
Nov 25, 2008 | Honeywell HE260A1010 Whole House...
Honeywell HE 260A1010
control board has eac terminal . will provide 110v to hum transformer anytime fan running.
also can pick up current sensing relay to sense blower power up and will then power the Hum. transformer.
Oct 25, 2008 | Honeywell HE260A1010 Whole House...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
236 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Ken Thomas
Soulvisitor
Soulvisitor
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
