Question about Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot
No response battery is new and charged. can I test the motor while on the trailer or does it have to be submerged to function.
I just put one on my boat today and had no problem with either the test button or running the motor while the boat is on the trailer. Your message said the "battery" is new. Did you get a 24 volt motor by mistake? If so, it won't run on a single battery.
Posted on Mar 02, 2009
Where is main relay on 2002 Altima I see relays & fuses no power to starter solenoid
I looked at info for 2.5L engine, automatic. Two voltage circuits at starter motor, one comes from the battery, hot all the time. The other terminal goes hot with key in the start position and starter relay is energized. Your neutral switch is also involved. Make sure battery has a full charge and battery connections all good. Any testing at starter motor, make sure tranny is in park or neutral and functional parking brake is set. Safety is your responsibility when testing.
Mar 09, 2017 | Cars & Trucks
I took the starter solenoid off a 1989 ford club wagon and replaced it with a new one, but now I have no power anywhere.
At the starter relay/solenoid under the hood. Two large studs, one comes from battery, hot all the time. The other one has cable that goes to starter motor. If you take large screwdriver and touch both large terminals at the same time, the starter motor should crank. If you try this, make sure tranny is in park or neutral and functional parking brake is set. You don't want the vehicle to move when testing. Safety is your responsibility.
Mar 07, 2017 | Ford Cars & Trucks
Same problem with my lumina not starting changed starter and battery and still not starting
Tell me exactly what happens, does the engine crank over or not? If it does crank do you have fuel pressure? Have you run fault code tests?
Jun 23, 2016 | Cars & Trucks
My regal will not turn over by key
You have a Buick, what is model year?
Make sure battery has a full charge and battery connections all good. At the starter motor, usually two voltage circuits, one is hot all the time, comes from battery. The other goes hot with key in the crank position and probably wired through neutral switch, for automatic. The starter motor usually grounds through the engine block. Any testing at the starter make sure tranny is in park or neutral and functional parking brake is set. Safety is your responsibility.
Is there a security system on this vehicle?
Jun 21, 2016 | Cars & Trucks
It was running fine, and then we heard a clicking sound and it just quit, now it will not start
Make sure battery has a full charge and battery connections all good. You can't do any testing if battery is down. Forget the jumping. Also, check your charging system.
Does starter motor crank? If not, check wiring circuits for the starter motor. Any testing at the starter, make sure tranny is in park or neutral and functional parking brake is set, Safety is your responsibility.
If you have a digital multimeter, you can do some testing. If the battery is down, put a charger on it.
Sometimes if battery voltage is lost, it can effect your security system. I haven't looked to see if it will effect your starter motor?
May 08, 2016 | 2009 GMC Acadia
What fuse goes to the 7-way trailer plug that charges the trailer batteries for a 2012 RAM 4X4
the power for the battery charging usually goes directly to vehicle battery with an inline fuse , hope this helps
Nov 22, 2014 | Dodge Ram 1500 Cars & Trucks
Plug pop-up into Tundra and truck backup lights come on
You have something Mis-Wired.... AUX is for the BATTERY CHARGING. You may have a GROUND ISSUE ALSO
Apr 15, 2013 | 2004 Toyota Tundra
Have no power out of the trailer plug 4or 7 prong,where should i look for the trouble?
Not sure which part you mean no power.
For the New Body style 2004 ( not a Heritage or Lightning model )
If both Stop / Turn pins & the parking lamps, might want to check the ground pin to make sure it is good ( or what you are using for ground on the test light / meter ).
The trailer tow parking lamp circuit is fuse #10 to the parking lamp relay
The stop / turn circuits also have fuses on each one, Fuse #36 & Fuse # 42 ( R & L ).
The 7 pin has fuses for the battery charge pin ( hot in run position ) and the reverse circuit ( hot in run & when in reverse ), Reverse is also fuse # 10 to the trailer tow reversing lamp relay & the battery charge pin is fuse # 106 to the trailer tow battery charge relay.
Could be all the fuses are blown, or what you are using for ground on the meter / test light is not a good ground.
Mar 16, 2011 | 2004 Ford F150
Why isn't my trailer connector charging the RV battery? I placed a fuse in slot 106, but it still doesn't appear to be working at the factory installed pigtail.
Might want to bench test the trailer tow battery charge relay.
You can also jumper this with a wire in the relay socket, to test the wiring to the trailer tow adapter. This is relay R05
Apr 20, 2010 | 2004 Ford F150
Pride sonic scooter won't turn on. the battery is charged and the motor is functional. Appears to be an electrical switch. any suggestions?
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Jul 08, 2009 | Pride Sonic 3 Wheel Portable Scooter
Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot Logo
264 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
