Question about Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty
Arctic Spa refill and a heater alarm ''HL''
Water is lukewarm and won't heat any more and no actual temperture on panel just tis HL alarm.
  • 125 Answers
HL is an error code. You will want to check out the link below to the mfg wesite. Balboa Water Group
Posted on Feb 26, 2009
    Habit-Forming:
  • 77 Answers
You may have a Spa Builders control system which was commonly used by Arctic Spas throughout their range.
Turn the hot tub off at the mains to reset it. If 'HL' returns again on the display you need to feel the heater tube. If the heater tube is not hot either, you have most likely got a faulty hi limit temperature probe (attaches to the heater), or a faulty PCB.
It might also be wothwhile checking the hi-limit probe connection on the PCB, these have been known to corrode and cause errors before.
The temperature probe is the cheapest item so try replacing this first.
Kind Regards,
Ian Kime.
http://hottub.synthasite.com
Posted on May 15, 2010
  • 35 Answers
HL stands for high limit error. Try turning the power off for 10 to 15 seconds and then turn the breaker back on.
Posted on Jan 21, 2018
HL problem
Posted on Jul 21, 2009
I have a tf325 bosch hotwater heater , problem is the flame will not stop when hotwater is turned off ?? Why and how to fix
After hot water has been drawn, the refill contents have to be heated to a set temperature in anticipation of the next demand. Otherwise, there would be a rush of cold or lukewarm water instead of hot.
Jan 27, 2015 | Bosch Water Heaters
What does HL on display panel mean
Thank you for posting your question here on Fixya.com.
HL stands for high limit...it means one of the high limit switches is open, preventing the heater from working. Either the limit has failed and replacing it will correct the issue or there is a situation with the heater or flow rates causing it to truly overheat...fixing the issue will return the heater to operation.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 23, 2011 | Arctic Pool & Spa
The HL indicator light comes on and I can not get it to reset. I shut spa off and the HL light was on again when I checked an hour later. I live in Wisconsin and don't want my tub to freeze. Tub was used...
It sounds like a flow issue. When the HL comes on, its sensing a higher temp than it is supposed to. This is usually caused by bad flow in the circulation pump.
The most likely cause of the bad flow in residential spas, is a bad filter element. Even if a filter looks clean, they do get clogged with particles we cant see. To test this, make sure the spa is free of debris, and remove the filter element. Run spa for a while and see if the code comes back. If it doesnt, get a new filter.
Otherwise the pump could either be failing, or clogged. Check this next.
Finally if these dont work, check the temp sensor (thermistor) .
Jan 24, 2011 | Arctic Pool & Spa
I have my hot tub plugged in for 3 days and the water is still cold, how long does it usually take to heat up a 8 man arctic spa?
If the cover and doors are on and everything is working then it should take no longer than about 8 hours.
It could be something simple like the heater is unplugged, or more complex like an airlock or faulty pump motor.
If you can't get service from your local Arctic Spas dealer, the head office service department can be reached through their worldwide corporate website, www.arcticspas.com
Dec 26, 2010 | Jandy Laars Lt 250,000 Btu Heater
I have a 2003 Arctic spa and have changed the heater. I have a HL sensor error on the panel but the tub is cold?
HL usually means that the heater is working and there is no water passing through it, do you get a flo error message before the HL,I had the same problem, mine was the flo switch
Oct 08, 2010 | Pool & Spa
HL displayed on digital control panel Aruba 1060
Jamie ...
Please do not sit in a tub that is, or claims to be, above 100 degrees F - unless there is a trained, licensed doctor or therapist watching you. 108 is deadly - don't find out by accident.
I think there is something seriously wrong with your tub - you need a pro to look at it. Your tub should not heat above 100 and it should only heat if the pump is running. If it is heating with the pump not running, it will quickly burn out and possibly cause other, expensive troubles.
Thanks for your interest in FixYa.com
Jun 07, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Our artic spa hot-tub is showing HL in the panel and is not heating up as it should. Everything else seems fine. Why?
HL is normally a "high limit" fault. If your filter is clean and you have sufficient flow, you may have a faulty high limit sensor. It should be mounted on the heater itself. The high limit sensor shuts the heater off if it senses excessively hot water. Check to see that you have sufficient flow, clean the filter, and make sure the filter pump is running. If everything else is running properly, you may have to replace the high limit sensor.
Dec 26, 2009 | Pool & Spa
1998 Tercel Cold heat to the windshield. Lukewarm out front vent.
Hey,
I just replaced my thermostat in my car due to the same problem. Except mine was a 92. I figured I'd start with the thermostat and antifreeze. Then the heating core. Now I have heat.
But yet I still have no heat on the windshield.
Oct 23, 2009 | Toyota Tercel Cars & Trucks
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
Arctic Above Ground Rugged Mesh Winter Cover Pool Size: 18' X 40' Oval Armor 8 Yr Warranty Logo
4,225 people viewed this question
Top Arctic Pool & Spa Experts
Mike Raino
Level 1 Expert
john h
David Spradling
David Spradling
Are you an Arctic Pool and Spa Expert? Answer questions, earn points and help others
