Question about Car Audio & Video
Dvd uv7i jensen parking brake pink wire how do i by pass this
Can you please help me bypass the parking brake pink wire for the jensen dvd player uv7i
  • goon1 Jan 29, 2009
    i have the some thing but if i put it to ground the fuse blows
  • JPtwohun Mar 10, 2009
    Isn't there a code that will do the same thing? Allow your passengers to view the dvd's while riding?
  • 15,935 Answers
Put it directly to ground.
Posted on Dec 29, 2008
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
Nov 13, 2008 | Jensen VM9510 Car DVD Player
Jensens UV9 By pass the brake
hook up the ground with the pink and when you are in am/fm mode hit the dvd set up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure it beeps after every no. has been pressed. then it should bring up the hidden menu select the hammer option and turn on the brake bypass option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
Nov 12, 2008 | Car Audio & Video
Jensen VM9311TS
plow boy442- I'm guessing you want your dvd to work while your driving. The unit has to be hooked to up to the e brake ,if you know which wire it is ground it out the unit will think your in park. Let me know , I can help you with this. cooltek Mar,3/08
Mar 04, 2008 | Jensen VM9510 Car DVD Player
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Phase linear UV7i makeing the dvd player without useing parking
There is a pink wire that goes to the parking brake. It connects to the ground wire on the parking brake that makes the brake light come on the instrument panel.
connect the pink wire on your stereo to a frame ground.
Oct 28, 2007 | Car Audio & Video
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
How do i bypass the parking brake switch in order for my video to play
isn\'t there a way to bypass the parking brake so my video plays anytime i want
Dec 15, 2006 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
1,066 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
