Denon AVR-800 and Sony ss-6000p speakers; Popping & Crackling!
Just recently my Sony ss-6000p speakers started to pop and crackle after i turned on my TV.
I have a Denon AVR-800 Surround Sound Receiver and up until now everything has worked without an issue.
Any Suggestions as to why these noises might have started occurring ?
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Losing volume on channels
I am afraid not. That crackling is a component in one of the solid state amp circuits starting to fail. These are all soldered into the printed circuit board. This could be a difficult repair to find an intermittant component. Depending on how old the unit is and how much it cost will factor in on if you have it repaired or not. Rule of thumb is that if the unit is two to three years old and cost less the 200 to 300 bucks you should not invest more then 100 to 150 bucks into it. Good Luck
Posted on Mar 16, 2007
SOURCE: hooking up an external audio source (IPOD) to the Denon AVR 3803
sure
just get a cable with phono plugs to mini phone connector Radio shack has them
Connect teh mini phone to teh earphone jack adn teh phono plugs to the aux inputs
select aux and enjoy
Posted on Jan 07, 2009
petraman7
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
My Denon AVR589 just started crackling like rice krispies, I've tried resetting the microprocessor, but no luck it still crackles. Is my unit fried?!
Is the sound from the unit itself (airborne) or is it through speakers only?
If the former, turn it off and take it to a tech to figure out what's sizzling in there.
If the latter, is it specific sources and/or specific speakers?
Mar 15, 2011 | Denon AVR-1508 Receiver
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Denon AVR-3300 has a buzz from all 5 speakers during warm up.
Depending on the location you're living, try to connect a good ground to your system might solve the problem
Jun 20, 2009 | Denon AVR-3300 Receiver
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Gateway Computer 710X Speakers are crackling/popping
It sounds as if the card itself may be physically bad. or you may have a microphone connected/something in your mic jack and you are picking up noise.
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
Gateway Computer Speakers are crackling/popping
yes it could be going out on you, if you have empty slot on mainboard or another computer you can try it on,then you can confirm if it is broke or not. hope this helps, glen
Nov 05, 2008 | Denon AVR-1905 Receiver
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
643 people viewed this question
 Grubhead
Grubhead
