Question about Motorola Radio Communications
I265 model its ringing on direct connect not the beeping i cant find how to get it to beep
  • eradiostore
    eradiostore May 11, 2010
    You might try posting in the cellphone forum.
  • 89 Answers
Go to your ringers menu, find the beep tone, (belive its ringer 10, while phone is the ringer is highlighted, press menu, then assign ringer as call alert. Hope this is what you're talking about. If you meant that it's not beeping when somebody presses the button to call you without alerting you, then you go to menu, settings, DC/GC options, and set "alert type" to ring. NOT vibrate or silent.
Posted on Feb 26, 2009
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
I hear rings and the comouter does not start
By rings, I think you mean beeps! Anyway, the amount of beeps means something. You need to tell us what PC model you have, or better still the mother board model, then we can tell you what's wrong. However, your memory sticks are a good place to start.
May 05, 2010 | Computers & Internet
My i265 won't turn on. It was acting weird and beeping for no reason last night but the radio worked fine. when I woke up it wouldnt turn on or charge
It's probably the battery. Batteries usually last 4-5 years before they completely die, and this phone model is 6 years old. Since this is an older phone model, the battery might be hard to find in a store (such as batteries plus) for a quick solution, but if you can, it should be pretty cheap. I'd say $15-25. If you can't find it in a store, they are about $6 including shipping online...but honestly, I would just upgrade to a new phone. You can get a simple phone usually for free, and it's a much faster and easier solution.
Jan 21, 2010 | Nextel i265
Boot up beeping problem
Hit VGA Card if it is not connected properly. If there is any dust, clean it by using an eraser.
Aug 17, 2009 | HP dx5150 Microtower PC Desktop
Ring scanner Beeps
Yes...you have a communication error. Contact Socket Support http://www.socketmobile.com/support/
Cheers...
Billy Barcode
Jul 28, 2009 | Socket Communications Cordless Ring...
Cant hear phone ring at a distance
Do you have a lifter installed?  You won't hear beeps in the ear unless a lifter is installed.  What type of phone system do you have this hooked up to?  Make sure it's a standard ring you're using and not a funky one.  The lifters tend to not recognize different sounding rings.
Apr 16, 2009 | Plantronics CS70 Wireless Headset
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
H500 soft persistent beeping
this sound is the sound of count down from going from a standbye mode to shutting off itself to conserve battery thats all this is
cant stop it unfortunatly its built in feature
Jun 04, 2008 | Motorola Mobility H500 Wireless Headset
Cant get ring tone or phones to work
This question was posted on the troubleshooting page for the VT-9118. This answer is specific to this model; other models have slightly different sequences.
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Mar 13, 2008 | Vtech VT-9118 Cordless Phone
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Radio Communications Logo
71 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
