Question about Epson Stylus Photo RX500 Printer
Screeching sound My printer got moved around a little yesterday, and I put it back in its place. Now when I try to print, I get a loud screeching noise. NYYYUUOOOOO WOOO, NYYYUUOOOOO WOOO ... I would upload a .wav but that might be overkill ;) Then I get a Paper Out error message on the display: "Paper out -> Load paper into the sheet feeder, then press the Color button." There's paper sitting in the feeder. Do you think it's just a particularly nasty paper jam? I don't see anything.
    Novelist:
    Champion:
  • 254 Answers
If you haven't already done so, look into the printer roller areas, and look for a piece of paper stuck somewhere, or maybe a paperclip or other foreign object which has found it's way into the mechanicals. Also, check the printhead assembly for free movement.
Posted on Apr 27, 2007
I have a Samsung Tab A6 that keeps making a loud screeching noise And boots itself it was freezing the screen but when I factory reset it that seem to stop now it's just making the loud screeching noise...
Where did you get the phone from.?
I suggest you take it back to them & get your money back as a screeching sound is usually a network-lockout noise from a stolen phone.?
Best of luck.
Mar 09, 2018 | Samsung Tablets & eReaders
Big Thunk when Frigidarie Front Loading washing machine started the final spin cycle, then at the end of the cycle soft screeching sound when drum is moving back and forth, any thoughts? amshap50@gmai
does not sound good. if you can remove a cover on front bottom or on the back you may find a broken shock, or counter weight, either would need replacing before running again
Jan 08, 2012 | Washing Machines
Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Oct 28, 2009 | Samsung RS2630SH Side by Side Refrigerator
Monitor makes loud screeching vacuum sound; no screen display..?
check to make sure that there arent any magnets near or around it
Apr 13, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Canon IR1600 Loud Screeching Noise During Copying
There are some little metal earth strips that meet the paper exit shaft at the fromt of the machine. I've had a couple of these digging intot he metal exit roller shaft, they just needed bending away from the shaft anbit and oiling. It also helps if you move the exit roller shaft from front to back a bit.
Mar 12, 2009 | Canon imageRUNNER C3170U Color Copier
Printer says it has a paper jam even after it has been cleared
The screeching sound is caused when the print head reaches the end of its travel and hits the paper jam which you cannot see using the suggested jam-clearing steps. So
1. unplug the printer
2. lift the cover so the blue support on the left holds the cover up
3. plug in the printer, watch the printer head move
4. after it stops, gently move the printer head toward the middle and look at the far ends of travel. you should find the cause(s) of the jam up against the sides of the printer. remove with needle-nose pliers.
5. replace cover, plug in the machine. it will go through a cleaning or 2, but it should be ready to go after that
Nov 23, 2008 | Brother Multi-Function Center MFC-240C...
Screeching noise from the carriage return after printing
Hi mothermoon,
This could be coming from dirty rollers. Raise the top of the unit and take some Q-tips dipped in isopropyl alcohol (rubbing alcohol) and start cleaning all the rubber rollers and especially all the steel rolling pins that are in front of those rubber rollers. Spin the rollers around, by hand, to make sure you clean all around them, not just one spot. You'll be surprised how much residue you'll get off these parts. Even if this doesn't help your particular problem it should be done as standard maintenance.
Aug 20, 2008 | HP PSC 2210 All-In-One InkJet Printer
Epson Stylus Photo RX500 Printer Logo
230 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
