Question about GE JVM1330BW/WW Microwave Oven
Our microwave stopped working suddenly. It's a GE JVM1330 and was made in 1996. The buttons on the control panel work fine, and the light inside turns on. We can enter a cook time, and it counts down as if it is cooking, but, it doesn't actually cook the food unless we pull the door gently toward us, without unlatching it. I recently put a business card in between the crack of the door, and it worked fine. However, now when I open the door, it sounds as though the microwave is on, even though I press "Clear/off" nothing happens. I'm baffled as to what the cause of the problem could be. Please help!
It's one of the micro-switches (3) that are part of the interlocking safety circuit. I actually took my switch apart and fixed it, but 99% of those out there would (and should) replace the switch.
Posted on Jan 16, 2009
  • bobdoc Jul 27, 2011
    Hello mackassoci, I am now experiencing the same exact problem with this same model (built May 1996).
    Where is the micro switch located? Do you have access to a scematic?
    Thank you,
    Bob
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
I put my Microwave on for 30 min and it suddenly stopped working, suggestions?
If there is no power at all to the display or the panel then it is failure of the board. But if there is power without heating, if the turntable/fan/light works, then it can be related to failure of relay, Magnetron, Waveguide or capacitor.
Jan 31, 2013 | GE JVM1650 1000 Watts Microwave Oven
My GE Prifile xl 1400 microwave works fine exept the light under it stopped working. I change the bulbs and still nothing. Is there a fuse just for the lights? or maybe some thing else.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Jul 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
Clock works panel lights up but it won't heat
All of a sudden last nigh it just started acting weird the panel works and the clock etc works as well as all the cooking setting. but it doesn't light up inside and when I close the door to my GE Profile Eterna Space maker it starts huiming like its cooking something
Feb 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
MY JVM1190WY MICROWAVE STOPPED WORKING SUDDENLY
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 29, 2008 | GE JVM1651 Microwave Oven
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
458 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
