Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV shut down now won't start back up.
Hi Majic Sea dog, my son was playing with his new PS3 when the TV cut out, we tried to resart green power light came on for 15 sec. then shut off tried many times but with the same results "CAN YOU PLEASE HELP!!!"
  • RCA Master
  • 5,138 Answers
Bad capacitors 3 of them cp150,cp114,cp120 on Deflection board if cp150 is puffed up on top it is bad ,so replace all 3 caps. Parts at Radio Shack.2200uf 16v and 2) 220uf 35v.
Posted on Dec 30, 2008
I was playing GT5 when the screen locked up. after about a second or two the system shut its self off. when I try to resart the red light will come on folloewed by the green, but as soon as the station...
I suppose what happened is called "YLOD". You can try some fixes found on search engines by keywords "how to fix ylod". There are some cool tutorials on Youtube too.
I can guess that it might be that Your system has just overheated and the protection did it's job to keep PS3 intact and not to burn it. You should let it cool down and try to get the disc.
Afterwards You should get Your system for maitenance and cleaning.
So, basically - there are good chances that it can be fixed; the disc should pop out when the system cools down enough. The game data can be copied from the system if it has hard disk or memory card.
I'll try to provide some possible fixes later.
Merry Christmas
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
I was playing a game then the ps3 shut off. now i can't get the ps3 to load. i tried unplugging everything and restart the ps3. i tried plugging it in a different outlet. i cut the ps3 off in the back,...
Do you have the red light of death I wonder??? What happens when you switch on your ps3. Does the green light come on, then beep at you and then does it go back to the red light? If so your ps3 is knackered!
Apr 10, 2011 | Video Game Consoles & Games
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shuts itself off in a sec and doesn't eject game.
HI, this is a power unit issue. you will need to replace the power unit block asap if possible. these can be purchase on line or, you can contact sony for this repair as well.
we recommend contacting Sony for the correct power unit for your system.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Will not play without using HDMI cable
  1. Make sure the AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
  2. Connect the other end of the AV Cable into the yellow Composite port for video, and into the white and red audio ports (if your TV does not have the red port, simply ignore it) on the back of your TV.
  3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 16, 2009 | Sony Playstation 3 (PS3) Console
No power at all
OKAY YOU SAY IT FLASHES GREEN AND RED!!! IS YOUR POWER CONNETED TO THE WALL OR TO WHAT???? I COULD SOLVE YOUR PROBLEM STEP BY STEP!!!
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
No picture any more
if your tv has a light blub replace it this is only for hdtvs
May 10, 2008 | Sony Playstation 3 (PS3) Console
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
