Question about Whirlpool Washing Machines
Machine stopped agitating and basket does not spin.
Had a large load of towels going and machine made an unusual sound. Machine will not agitate or spin now just hear the motor running. I took all towels out to see if it would run without anything in it but water, but still no movement. I previously posted this about a hour ago but somehow the model number changed during my post. The machine is a Whirlpool Ultimate Care II LSQ8243H Washer
  • 1 more comment
  • gulfbeach47 Dec 28, 2008
    Not sure if my reply is showing up. i don't see it, so I will post again. What is a coupling and is there somewhere to find out how to replace? Is this an easy job for someone not mechanically inclined?
  • gulfbeach47 Dec 29, 2008
    I see the coupler located on the parts repair list in the middle of a bunch of other parts. Real nice of you to offer to the help. I have so much on my plate right now, that I probably should not attempt to repair myself. Since the coupler is cheap, what would you say would be a fair price for repair done at my home? I guess it would be better to get it repaired, rather then buy a new one unless repair cost is outrageous
    onthejob5130 Thanks so much for your help. I never heard of this site until I posted a question about my machine in the local newspaper. Are you a paid worker for FixYa or just someone that offers free advice? So your advice would be repair and not replace? Also, I guess this repair could cost over $100.00 after looking at what is involved getting to the coupler and of course the price of labor per hour.
  • 640 Answers
Replace coupling,,,
Posted on Dec 28, 2008
  • 1 more comment
  • onthethejob1
    onthethejob1 Dec 28, 2008
    the motor coupling is between the gearcase and the motor,,the price of a coupler is cheap,,,its there so if you overload the machine ,,you wont brak transmission or burn out motor,,,i can talk you though..even if you never pick up a screwdriver,,,glad to...this is the part you need#283753A
  • onthethejob1
    onthethejob1 Dec 29, 2008
    i cant give you a price ,,because servicers charge buy area and distance,,try a couple and shop around,,,good luck
  • onthethejob1
    thank you gulfbeach,,
When i turn the knob to hot water on washing machine no water comes in
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Dec 02, 2012 | Maytag Washing Machines
The agitator in the machine stopped working. I can spin it freely by hand in either direction
Sounds Like the agitator dogs are worn or broken. they are easy to change
  1. Remove the Fabric Softener Dispenser (#1 on diagram)
  2. Remove the Agitator Bolt. (#2 on diagram)
  3. Replace the Agitator Repair Kit
There are 3 Lengths of agitator cams
If you go to http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503228&diagram_id=28254127#d28254127
And Click on #20 on the Agitator, basket and tub Diagram
You can see pictures of the 3 lengths of cams order the one that matches your washer
Jun 25, 2011 | KitchenAid KAWS700L Top Load Washer
The washer quits spinning sometimes, mostly when
May have a basket drive going bad. Not a bad job but can be tedious to get to.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Washer stopped agitating and spinning
the most common problem after a large load is the motor coupling has broke. it is what connects the motor to the transmission. it is not hard to replace if you can get the cabinet off the unit. you have to take the control panel loose and "hinge" it back to get access to the clips that hold the cabinet on to the frame. once you remove the cabinet, then take off the pump clips, the motor clips and then the motor. that will allow you to get to the coupling and replace with a new one. sounds easy but its not for a first timer. good luck and hope you can find this of some help.
Dec 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud noise at end of spin cycle
Jun 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal De
