Question about Countryman ISOMAX E6i (E6IOW5BC2) Microphone
I have no sound from my E6
Alright...my E6 just stopped working.  I plug a regular headset or lav mic into the body pack and the mics work great but the E6 gives me nothing.  I thought it might be a short but when I wiggle the connections or unions, there is no crackle or pop.  Any ideas??? or known problems??  Thanks.
  • 3 Answers
Check the headset closely around the mic capsule and ear attachment for placing the mic on your ear. This is prone to problems from bending the mic to fit different people. You may find a break in the metal under clear rubber material. Also the cable itself could have a problem. Countryman sells the cable and it unplugs rather easily. There is a junction in the cable that is actually a plug. You can pull it apart there. Be careful as the mic is very expensive. Also countryman provides excellent technical support. Good luck.
Drobertson
Posted on Feb 02, 2009
My Shure mics work fine but two bodypacks are not working. Are there fixable parts in there?
Try switching mic's with known good system. The small diameter cable going to headset and lav mic's are easily damaged. If the mic feeding the bodypack is good, fresh battery, mute disengaged and channels set properly then it's Shure factory service time.
Feb 06, 2013 | Shure SLX1 Body-Pack Transmitter for...
Is there way to tell if the e6 mic is having
You likely broke one of the 4 wires between the circuit board in the pack and the connector for the mic when you replaced the antenna lead. These leads are hard to work on and the solder can pull away. They can appear to be connected and not quite touching... a gentle tug to test each one!!!
Feb 09, 2010 | Countryman ISOMAX E6i (E6IOW5BC2)...
Headset mic won't work.
What have you done to try to fix it I need to know so I can help you fix it and Mabry you need new headsets
Nov 18, 2017 | Logitech (980158) Headset
Mic is not recognized
i have a GE 98980 headset and window vista wont reconize the mic but the headphones work fine. How do i get the mic to work?
Jun 02, 2009 | GE (98980) Headset
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Mic is popping
It sounds to me like you have a short in the cable. Power up unit like normal and move the wires at each end of the cable, mic end and connector end, being careful not to move the mic. If you hear popping it's a bad cable. If not, now gently shake the mic, does it pop, then it's your mic's capsule and needs replacement.
Apr 03, 2009 | Shure ULX1 Body-Pack Transmitter...
HP Premium Sterio Headset ( mic also ) not working.
go to sound settings and then enable the mic by checking off the box.
Mar 28, 2009 | Video Game Consoles & Games
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
My microphone just stopped working, what can i do? My headset microphone quite working on my Sound Blaster X-Fi card when the new Creative Labs update came out......... headset/mic works on another...
If the driver is alright of course is a setting or you haven't plugged the microphone right on the sound card. See also if the micro is cut from the settings or or the volume is low. Check these first
Sep 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
Countryman ISOMAX E6i (E6IOW5BC2) Microphone Logo
332 people viewed this question
Top Countryman Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Countryman Audio Player and Recorder Expert? Answer questions, earn points and help others
