Question about Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 350-can not change the location it is stuck on
Top of screen says it is acquiring satellites..but it does not matter where I take it, it says the same thing - it is locked on an old location when we were driving...Has question mark over where it says we are driving.
  • DavidTeo Jan 01, 2009
    I have the same problem. When it is working, the device would ask you to go to "highlight area or ground".
    I have done the following based on solutions recommended:
    1. http://www.garmin.com/garmin/cms/site/us...
    a. Installed the latest software
    b. did a master reset - pressing the top right screen - favorites were
    not deleted
    2. Run the the battery flat by keeping it on and re-charging it. One person
    fixed this problem using this method. It did not work for me.
    May have to call support soon product support at (800) 800-1020
  • Anonymous Feb 05, 2009
    I have the same problem. It always shows the last location i was in and just not able to aquire any satellite signal. Even though i tried all option. I dont know what to do. Can someone help
You may need to reset it, as in resetting the c340, turn off and then press back on again, if this does not work maybe the reset button is in the same place as it is on my c340, instructions for the c340 is as follows: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plat, press the reset button, turn the unit back on and hopefully it will operate normally
Posted on Dec 29, 2008
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
MY Garmin first Said that it was acquiring a satellite then it is stuck in one city and won't clear to set another route. what can i do?
Did it actually acquire any satellites. If not try the reset button on the back. If nothing then do a master reset - you may lose some of your locations previously stored or user data. If none of these work or before you try them try an external antenna.
Oct 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi not acquiring satellite
I am having the same problem with my nuvi 350 and its about the same age. I read on another post it may need a new battery but you need to send it to garmin. I am going to contact garmin directly.
Aug 20, 2009 | Garmin nuvi 350 GPS Receiver
Wont acquire any satellites
Have you tried an external antenna? The flip antenna's are known to give problems,
May 12, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 350 Nuvi
not sure if you are keeping the tab open but...the reason is because the tab at the top of the GPS is the antannae. You have to open it or it won't work. when you press the reset button, you are opening the antannae first which then acquires the satellites. Keep the top tab open.
Sep 21, 2007 | Garmin nuvi 350 GPS Receiver
I cannot acquire satellites signal. What to do ?
I experienced the same problem about acquiring satellite signal even when it's a clear sunny day. After 30 mintues, it was still searching! The unit appeared to have "stuck" in this acquiring mode. The following worked for me: 1) open the GPS antenna 2) press the bottom left screen while holding the power button to turn the unit on 3) enter maintenace mode 4) select diagnostics 5) clear error report, do NOT clear any user data 6) restart unit the usual way My GPS 350 was able to acquire satellite signal in less than 1 minute after the above steps were taken.
Jul 21, 2007 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Car GPS Receiver Logo
1,192 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
