Question about Acer Aspire 5315 Notebook
I have a new Acer Aspire 5315-2698 with only 2- 512 MB RAM. I want to replace this with 2 1GB RAM. I need to access the existing chips. How di do this? The chips are presumably accessible on the bottom of the laptop, but the only panels which seem removale are the battery panel and another panel which the limited info in the handbook accompanying the computer says is the location of the hard drive. Even so, I loosened the two screws which seem to hold the panel down, from which I expected to find access, but the panel doesn't come up. Any suggestions?
  • 903 Answers
Http://members.aceweb.com/gregg1/acer/Inside_Acer_Aspire_5315.html
go here for a picture of the inside of acer 5315 and how to remove the cover to access the ram
I hope this helps
Posted on Dec 28, 2008
RAM Acer Aspire 1403LC
Look for a 512MB 200-pin SODIMM DDR PC2100 266MHz
Jan 22, 2014 | Acer Aspire 1403LC Notebook
I have Acer E500 with 1GB Memory the window did not show complete memory size.see what i got: installed memory (RAM): 1GB (767 MB Usable).
the windows uses 223 MB for the operating system to run smoothly. thats what it means. your ram is perfectly working. any further assistance please ask and rate me Kronoguy
Jul 07, 2011 | Acer Aspire E500 PC Desktop
I wanted to get my acer aspire T180-UA381B upgraded, and I know very little about computers, how much and what kind of ram should i put in to make it run fast
Based on your memory specs below the maximum RAM that you can install in your computer is 1GB
DDR2 SDRAM and you can get 1GB RAM for like $15 -$ 20. 1 GB DDR2 SDRAM is what you need to buy.
Your Memory Specs:
Installed Cache Memory: 256.0 KB
[close] Installed RAM: 512.0 MB RAM, or Random Access Memory, is the place in a computerwhere the operating system, application programs and data in current use arekept so that they can be quickly reached by the computer's processor. Theamount of RAM you have affects how quickly you will experience your computerworking.
[close] Installed Video Memory: 512.0 MB
[close] Max Supported RAM: 1.0 GB
[close] Number of Memory Slots: 4 x 240 Pin DIMMs
[close] RAM Technology: DDR2 SDRAM
Feb 11, 2011 | Acer ASPIRE T180-UA381B DESKTOP PC
How do i install a memory ram on my computer acer 5050
I don't know your model laptop, but most laptops have one or two memory slots on the bottom of the laptop behind a panel. Remove the panel to reveal the RAM slot/s.
When installing RAM, say 1Gb when there is two 256Mb RAM modules, then you need to replace the existing RAM with two 512Mb RAM modules. Make sure the new RAM is the same speed as the original RAM or faster RAM.
Oct 16, 2010 | Acer Aspire 5050-3242 Notebook
What is the maximum size i can upgrade my acer aspire 1350 laptop
If you are referring to Memory RAM the the answer is 2048 MB using two 1gb sdram chips. Some models will use DDR memory. For more details visit the page listed here:
http://crucial.com/store/listparts.aspx?model=Aspire%201350%20Series
Hard drive space is only limited to how much you want to spend.
If this helps please rate my answers.
Brett
Mar 20, 2009 | Computers & Internet
RAM / HDD upgrading
u need 1gb Ram in total it is more than enuff for u u will never feel short after this and sure it will boost performance , u have 512 mb
if u have 2 chips of 256mb each then u need to buy 512mb X 2 chips and ur old ram will be left with u , luckily if u have 1 chip of 512 mb in ur system then u will save money like only buy 1 chip of 512mb but pls check the whole ratings of ur RAM and make of RAM is it samsung or hynix chips or what bcoz u will have compatibility issue in matching ur old and new rams pls let me know of whole specs written on RAM i can help u in matching
if u need urgent boost in performance then i will suggest replacing hard disk u will see a big change in loading OS and opening programs RAM is secondary in this stuff , but it is imp u can also go for 756 mb in total if u dont want to waste money if u have 2 chips of 256 each
secondly go for 160/250 GB 7200 RPM drive for top performance but 5400 RPM is still fast in ur notebook it is like 4200rpm according too my expertise
pls rate me FIXYA for my analysis if u like
Mar 08, 2009 | Acer Aspire 5100 Notebook
Acer aspire rejecting memory at 2gb
so u have three chips am i right 1gb+1gb+256mb
basically its RAM compatibility issue check the ram specs is it ddr 2 with the specs that suits ur system or not
if u put 1 gb and 1gb it gives u issues then kindly check the DDR2 PC???? check is it 2100 4200 or 5300 what is ur orig ram rating try the same rating and then check pls also check the bus speed is it 533mhz or 667 or 800mhz
pls only use the compatible ram with ur laptop kingston are good with acer bcoz originally it comes with hynix chip and kingston chips nomally and sometimes samsung chips let me know about the detailed specs of all chips with all digits written on them
pls rate me fixya if ur problem is solved
Mar 04, 2009 | Acer Computers & Internet
How to change add RAM to Acer Aspire
first check with www.acer.com to see that expansion is possible.
all computers like their memory upgrades in sets, instead of singles(like changing both front tires on your car or truck)..so compatibility among the two is more vital than matching to existing ram cards.
Feb 17, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5315 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
