Question about Gateway E-2000 Deluxe PC Desktop
Desktop PC issues...
Hi, Matt here!
~My desktop is acting up: meaning I turned it on this morning and it sounds like it's running, but it has not started up....
...any idea as to why this is happening?
  • 4 more comments
  • matt_bones19 Dec 28, 2008
    Its not the's the tower. As I mentioned before, I turned it on this morning and it sounds like it's running (fan sounds), but it's not starting up.
    No beeps, the normal blue light isn't on...
  • matt_bones19 Dec 29, 2008
    Well the tower would need to come on first to tell the monitor to come on, right?
    So 'no', there aren't any 'error' messages.
    I plugged my monitor into my laptop's docking and its working I'll check everything else out, with a follow-up report.
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Any beeps or flashing lights?
  • 46 Answers
Verify that the monitor is on and that it is connected correctly. Monitor cords can often come disconnected
Posted on Dec 28, 2008
  • Adam
    Adam Dec 29, 2008
    Are there any error messages at all on the display or is there anything that shows up on the display.
  • Adam
    Adam Dec 29, 2008
    Ok you have said that the computer is making sounds like it is on right - This tells me that the computer may be on.
    As soon as the computer starts to boot it will start displaying images on the screen but the monitor has to be on first - Are there notmally any lights that are on on your monitor? typically a green light or an amber/orange light.
    If not make sure that the power button is turned on on the monitor - just to be on the safe side if it is already on or if it is not on turn it off and then on again.
    Then look at the back of the tower and make sure that the cord that goes to the monitor is still plugged in you may want to unplug it and then plug it in again as well.
    Since there are no beeps at startup when you first turn on the computer this may mean that you either do not have a post or startup issue or you do not hace a PC speaker or motherboard speaker in your tower.
    You will typically get beep codes if your:
    Video card is not plugged in or has gone bad
    Memory is not plugged in or has gone bad
    You may want to try another monitor just to verify or plug your current monitor into another computer.
    You may want to start up your computer in safe mode in the event that display properties or a bad driver has changed your settings try turning on the compuer and tap on the F5 key for a few seconds and see if anything changes.
    Since you are not seeing any lights on your tower and not getting any beep codes I would recomend checking your power supply, Processor, and motherboard.
    Please keep in mind that of all the parts in a computer, the only part that can make everything else look broken is the power supply.
    Good Luck
Desktop won't make a sound when I turn it on
Check to make sure the power switch on your surge protector hasn't been reset - also check the connection at the back of the computer -
Jan 15, 2013 | Systemax Venture PC Desktop
My computer has recently decided to stop working. I can turn on the tower and the monitor to power it up and the tower does it's normal thing like it is working, the screen on the other hand stays...
If you mean you didn't get any display in your monitor the first solution is u must reinsert your memory and memory slot.if still have the same issue confirm your monitor is connected to your tower properly.if you still have the same issue just replace your memory (ram).thank you.
Sep 05, 2011 | Compaq Presario 5000 PC Desktop
Good morning -- I am having an issue with my volume - I have it on the highest possible, but my speakers aren't able to pick up much still
Does any sound at all come out of your speakers?
1. Go to Start > Control Panel > Sounds and Audio Devices
2. Under the volume tab, turn your "Device Volume" bar up
3. Also, click on "Speaker Volume" at the bottom and adjust both left and right speaker bars up
Jul 20, 2011 | HP Compaq Presario SR1920NX PC Desktop
Blank screen on my HP IQ506 TouchSmart
Hi, you may need to do a system restore with your windows CD or try pressing the ESC button during boot up and select start in safe mode, from here you can restore your operating system to a time before the problem started. Hope this helps
Jul 14, 2010 | HP TouchSmart IQ506t PC with Intel Core 2...
TouchSmart IQ770 PC Desktop: I have no sound...
download sound drivers
May 17, 2010 | HP TouchSmart IQ770 PC Desktop
I turned on the computer to allow it to download
not as far as im aware try removing the 24pin connector from mobo and replacing it then reset the bios jumper by jumping it from norm to reset then turn on pc for a second turn pc off and jump it back power up pc and this should fix issue
Jan 01, 2010 | Sony VAIO® VGC-RC310G PC Desktop
Sounds coming from desktop
There may be several reasons for this like software conflict or may be a hardware issue.
Kindly let me know when desktop produces weird sound, I mean does this happen when you open any application or something..
But in the meanwhile, you can try the following :-
Step 1 - If you are technically sound then try to open computer tower,open sound card from the slot and put back in.
Restart your machine and check results,Kindly post your results..
Hope it helps !
Oct 06, 2009 | Computers & Internet
Desktop icons
Right click on the desktop;
Arrange icons > Auto arrange
untick auto arrange and there you are a clear organised desktop :)
Jan 22, 2009 | Toshiba Satellite Pro L300 Notebook
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
My girl left me and changeg my login password
Let me know what kind of PC Desktop you have,. Any way turn on your PC once get started press F8 then safe mode when the windows start at safe mode go to control then user account click the user that has a password and start to remove the password
Mar 22, 2008 | Computers & Internet
Gateway E-2000 Deluxe PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
