Question about Motorola Mobility HS850 Consumer Headset
My headset does not hold its charge
My headset is about a month old. I had not had any problems until about a week ago. I charged it overnight and by 1pm after minimal use, it is dead.
  • kevin busch May 02, 2007
    That worked. Thanks for your help.
  • 106 Answers
Usually Lithium-Ion batteries have a Memory effect, ie. the battery should be 100% consumed then only recharged. If the battery is only 40% used and recharged then the battery will give you only 40% of it's total charge. The battery starts showing you empty after it is 40% consumed even it was 100% charged. Now there is solution for this-Drain battery upto full, store it in a cool place like Frigde then charge it full then again use it upto last. Repeat this procedure for 2-3 times.Your battery should come to normal state. Also check the charging current of the charger.The charger might also be faulty.
Posted on Apr 26, 2007
1996 lexus es300 not holding charge
Make sure the battery is good. U can charge it and disconnect it from car overnight and see if it works the next day. If it is still fine then the car has a drain. If no good, then the battery is bogus and cannot hold a charge.
U have something in wiring that is draining the battery after shutdown. Need an ammeter. Hook it up to the battery and wait about a half hour. Then notice draw on meter. Start removing fuses until you locate the line that is responsible for the draw. Then check out each and every item on that trunk line.
Jun 23, 2017 | Lexus Cars & Trucks
I have a hbs-760 Bluetooth headset and it won't charge it'll say it will but when I charge it overnight I still says battery low can you please tell me what the problem is thank you
LG Tone Pro HBS-750 repair, upgrade, mod - YouTube
? 12:58
https://www.youtube.com/watch?v=WXHkFXOJgRU
Oct 8, 2014 - Uploaded by kez3000
I have HBS760, when i 1st bought it about 3 weeks ago volume was fine, .... mine wont charge anymore or turn on. can it be fixed? and is it the .... LG Tone Infinim HBS-900 Bluetooth Headset Repair & Review - Duration: 4:39.
LG HBM-760 Bluetooth Headset Charge - Questions - Fixya
www.fixya.com > ... > Headsets > LG > LG HBM-760 Bluetooth Headset
Jan 06, 2016 | Radio Communications
Hi , I bought a rosewill bk-500a ,now it will not keep a charge. It is only about two weeks old. Any ideas ?
Even though it's new the battery may be shot. I bought something and it said battery good for three years and it lasted for a week. Either take it back or replace the battery yourself if you want to try. But my advise is take it back if its new.
Dec 31, 2015 | Samsung Radio Communications
BT-38k will NOT charge. its new, just bought it 4 hours ago, and it wont charge up
Let the unit charge overnight to make sure that is the problem, if there is no change return the item for exchange.
May 21, 2011 | Just Wireless Bluetooth Headset Wireless...
My Plantronic 230/R explorer headset completely lost it's charge. When connected to its charging adapter the red light come, stays red for a few minutes then goes out without charging the headset device....
Dear Allen
Im strongly recommend you, buy a new original charger otherwise you can damage your headset.
The red light you saw probably because your charger is not compatible.
You can buy a new one via eBay.
Mar 03, 2011 | Cell Phones
I've had my plantonics headset for two weeks now and has worked great. Today, however, when I went to turn the unit on after it was recharging all night, holding the power button did nothing. I plugged...
This is probably a problem with the internal battery.
Some devices do not need to be charged for a very long time as this leads to eventual destruction of their battery.
The only way i can specify for you is for you to do the following.
Put it on charge and try turning it on, see if it comes on. If it does, the battery may be spoiled so cannot retain charge to power the device as it may have been over charged.
Also, if this doesn't work for you, the only thing you can do is to send it to an accessories store for check up or for repairs.
Hope this helped you? Please comment for more information.
Jan 21, 2011 | Plantronics Backbeat 903 Bluetooth...
Hello, My Garmin 260 ran out of battery 3 months ago. I did not attempt to recharge it until two weeks ago. i used a usb cable and plugged it into my computer overnight. It still did not charge... what...
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+260&Show=ExtInfo&gclid=CLzv0pac46ECFQQTawodklsxIg.
This place has the battery and tools come with it!. its super easy and way cheaper than buying a new garmin. 2 screws and unplug the old battery and plug in the new. I did mine and I never messed with the internals before.
May 03, 2010 | Garmin nuvi 260W GPS Receiver
Will not turn on or charge
get warranty on that one.
Jun 23, 2008 | Jabra BT125 Headset
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Motorola Mobility HS850 Consumer Headset Logo
356 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
