Question about Nokia N72 Cellular Phone
My N72 got spoiled.
My N72 fell down and i unknowingly mached it with my leg before i realise.When i picked it up i discover that it has gone off with a little mark of ink on the screen.I try 2 on it but it couldnt get on,when i plug the charger and on it again it got on but blinking before it got off again i took it repairs they try flashing it and changing the screen even the power but it could not even bring light not to talk of operating well.so could you please help me i dont want to loose my N72.
My sille phone don't show to me my numbers calls so how can i solve it?
Posted on Jan 03, 2009
How do I my wedding ring out of my washing maching, it fell in there last night, on the top part between the lid and the top back part
If it fell between the bole and the housing the cover will have to be removed. if it can be turned upside down it may fall out. If it is inside the bole it may be under the agertater or or in the water pump housing.
Jul 18, 2014 | LG Washing Machines
I was changing the front disc brake pads on my 2008 Suzuki Boulevard S50. I took the two bolts out that hold the calipers together which caused the fluid to leak out and a small rubber gasket fell out ....
You will need to buy a new rubber gasket kit for caliper from suzuki shop
It is not usual to pull caliper apart for pad replacement, normally unbolt caliper off fork leg and lift of the disk
Jul 08, 2011 | 2008 Suzuki Boulevard
My nokia n72 mobile was fell into water and..not working and mobile mechanic also given up what should i do now.
Water damaged the motherboard of your N72 that's why it is not working.
Instead of taking it to mechanic take it to Nokia care center.
They will surely sort this out.
Jun 21, 2011 | Nokia N72 Cellular Phone
I have pulled the dryer apart at the back and discovered the fan is not working. Is it fixable or should we just buy a new one . It is a Simpson Sirocco 450 Dryer.
well this one is down to you ,,how old is the dryer? how much to fix it? how long will the patch job last? how much life is left in this unit?
how would you like a new unit???? how good will it fell to show off a new unit?,,,go for it,,,spoil yourself!
Jul 21, 2010 | Dryers
N72 fell down keyboard not working
theres no choice but to buy a new one
Jun 20, 2010 | Nokia N72 Cellular Phone
My Three Memory Card has been lost in N72 set What is these problem
Hi, you are always loosing your memory card because the place where you slot in the memory card which is beside the phone is not tight enough to hold the memory card. Since it isn't tight enough, the memory card will always fall off unknowingly to you.
You have to take the phone to a phone repairer to tighten up the memory card slot space.
Take care
Apr 09, 2010 | Nokia N72 Cellular Phone
I HAVE REPAIRED THE RUBBER DRIVE COUPLING ON MY WHIRLPOOL 3LBR6132EQ TOP LOADER. WHILST REPAIRING IT A FLANGED PIN OF 10MM DIAMETER FELL OUT. THE WASHING MACHINE SEEMS TO HAVE VERY BAD VIBRATION IN SPIN...
The pin fell out of a catch cup used for transporting the washer when new. It is not important unless you put it some place it does not belong.
If you laid the washer down to do the repair you probably got the base plate out of alignment. Open the lid,reach inside and grab the wash tub. Pick it up as much as you can and shift it around. It will usually reseat the plate.
Also block the front of the washer with your foot and raise the rear of the washer off the floor. The self leveling legs should drop down. Let the back of the washer loose and it will settle in on the leveling legs.
This washer should be left in the upright position to change the drive coupling.
Jan 04, 2010 | Whirlpool Washing Machines
BLANK SCREEN
try to open it and check for loose connection from your lcd to your cellphone board.
Nov 17, 2008 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
