I have new computer and I wan to get rid of mystartincredmail.com
    Novelist:
    Scholar:
  • 72 Answers
You should be able to go to Control Panel, select Add/Remove programs and remove Incredimail.
Alternatively, you may be able to go to Programs > Incredimail > and select to uninstall.
Let me know if that does not work.
Honest1abe
Posted on Dec 28, 2008
    Scholar:
  • 46 Answers
Where are you seeing mystartincredmail.com?
If it is the first thing you see when you open your internet browser try this.
Open your browser.
Select tools from the top of the screen
Select internet options
In the first section change the default website url or choose the option that says Use Blank
Wan driver not installed? where can i find it with
Go to Acer support site or copy this link in Browser (http://www.acer.com/worldwide/support/download.htm) and enter your location, now new page will be opened you can send me your laptop model no, serial no, service tag. then I 'll be able to find appropriate WAN drivers. hit me at jogindersingh47at yahoodotcom
Aug 17, 2013 | Acer Aspire Computers & Internet
Two routers, two WAN links
easy...
CODE
!R1
interface GigabitEthernet 0/0
ip address 172.16.1.1 255.255.255.252
ip ospf network point-to-point
bandwidth 100000 ! Makes OSPF think its 100Mbps
interface GigabitEthernet 0/1
ip address 172.16.2.1 255.255.255.252
bandwidth 10000 ! Makes OSPF think its 10Mbps
router ospf 10
network 172.16.1.1 0.0.0.0 area 0
network 172.16.2.1 0.0.0.0 area 0
network 10.1.1.1 0.0.0.0 area 0
passive-interface GigabitEthernet0/0/0
!R2
ip address 172.16.1.2 255.255.255.252
ip address 172.16.2.2 255.255.255.252
router ospf 10
network 172.16.1.2 0.0.0.0 area 0
network 172.16.2.2 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
This will make your wireless link preferred, if the link fails the OSPF adjacency will fail and routing will fallback to the other link.
You should ideally have some /32 loopback interfaces so the router will use this as the OSPF RID, or manually set the RID under the OSPF process.
More discussion about this you can see http://www.router-switch.com/forum/showTopicDetails/11/490
Apr 12, 2013 | Cisco Computers & Internet
TATA PHOTON+ Dialer Error 720: A connection to the remote computer could not be established. You might need to change the network settings for this connection. Can anyone fix this problem??? I'm using...
f you are experiencing this when trying to use Dialup Networking (ThinkPad Modem) or Verizon VZAccess Broadband, the following may be useful. Note, the solution involves modifying the registry on XP so it is not for the faint of heart.
Note that a key symptom of this problem is that the modem connects and then disconnects just after trying to register the computer on the remote network.
Step 1: Uninstall the WAN Miniport (IP) and WAN Miniport (PPTP)
IMPORTANT: This procedure contains information about modifying the registry.
Before you modify the registry, make sure to back it up and make sure that
you understand how to restore the registry if a problem occurs. For
information about how to back up, restore, and edit the registry, click the following
article number to view the article in the Microsoft Knowledge Base: 256986
(http://support.microsoft.com/kb/256986/EN-US/) Description of the Microsoft Windows Registry
SYMPTOMS
When you try to use a dial-up connection to connect to your Internet Service
Provider (ISP), you may receive the following error message during the
"Registering your computer on the network" portion of the connection
agreement:
Error 720 - the connection attempt failed because your computer and the
remote computer could not agree on PPP control protocol.
Additionally, when you view the devices in Device Manager, you may notice a
yellow exclamation mark (!) over the icon for the WAN Miniport IP (#2) device.
CAUSE
This issue may occur if the TCP/IP protocol has become unbound from the
dial-up adapter, or if a conflict is created when a second WAN Miniport IP
device driver loads.
RESOLUTION
To resolve this issue, uninstall the WAN Miniport IP and PPTP devices.
To do so, follow these steps:
1. Right-click My Computer, and then click Properties.
2. Click the Hardware tab, and then click Device Manager.
3. On the View menu, click Show hidden devices.
4. Under Network adapters, you will see WAN Miniport IP
devices. If a WAN Miniport IP device is listed, continue to the
following step. If no WAN Miniport IP device is listed, go directly
to step 16.
5. Click Start, click Run, type regedit in the Open box, and then click OK.
WARNING: If you use Registry Editor incorrectly, you may cause serious
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
6. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-
08002BE10318}
7. On the Registry menu, click Export Registry File, type backup-key in
the File name box, and then click Save.
Note You can restore the changes that you make to this registry key. To do
so, double-click the backup-key.reg file that you saved.
8. Click each of the registry subkeys under this key, and then view the Data
column of the DriverDesc value to determine which of the subkeys
corresponds to WAN Miniport (IP). For example, the 0005 subkey.
9. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) or
WAN Minport (PPTP); (for example, right-click 0005), and then click
Delete. Click Yes to confirm that you want to delete the key.
10. Quit Registry Editor.
11. Right-click My Computer, and then click Properties.
12. Click the Hardware tab, and then click Device Manager.
13. On the View menu, click Show hidden devices.
14. Under Network adapters, right-click WAN Miniport (IP) and then click
Uninstall. Click OK to confirm that you want to remove this device.
15. Repeat for the WAN Miniport (PPTP).
Step 2: Reinstall the WAN Miniports
1. Find netrasa.inf in c:\windows\inf
2. Make a copy of the file and name it netrasa.inf.save
3. Open the orignal copy of netrasa.inf and place a semicolon
in front of the line that starts "Excludefromselect=\" and
and continue with all follwing lines and then end with
"MS_NdisWanNbfIn,MS_NdisWanNbfOut" under the [ControlFlags]
section. (all lines between)
Step 3:
1. Start a Add new hardware session (from Control Panel) and choose
that the hardware is already installed. Choose to "Add New Hardware"
and then select "Network Adapters" followed by "Microsoft" and then
both the PPTP and the IP Wan miniport one at a time.
(NO need to reboot between these steps)
2. After you finish both then reboot.
3. Select Start -> Run and type: netsh int ip reset c:\resetlog.txt
(For details, see http://support.microsoft.com/kb/299357)
4. Reboot and try your connection.
5. Delete the modified netrasa.inf and rename the original (which was saved as netrasa.inf.save) back to netrasa.inf
Jun 30, 2011 | Sony Computers & Internet
Idk what 2 do w/ this iview netbook my daughter just got for christmas! i have comcast internet. that modem did go into my desktop but my desktop just broke so now comcast modem runs to a belkin wireless...
Under WAN settings: Enable Dynamic and Hostname : http://www.comcastbroadband.co.in (If above settings not works clone computer MAC address and assing to WAN port) You have to wait for 3min to max.then it will works. Step 2: By default DHCP enabled and IP will assigned to your computer and all connected devices. Step:3 First time you have to login with comcast website it may computer or laptop or any other device
Simply copy the WAN configurations from your laptop to your netbook WAN settings
Dec 22, 2010 | ASUS Eee PC 1000HE Netbook
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
I can get a computer on the LAN but not the WAN. All the other computers work fine but I just got a new one and am having this problem.
The WAN (Wide Area Network) port is used for access to the internet through the use of a DSL or Cable modem.
You can't connect a pc to the WAN port it must be connected to one of the LAN ports.
Jul 12, 2009 | Cyberguard SG530 (SG0064US) Firewall
Cant hook up
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router
insert satalite into wan port, set up router
run a client wire from the router to a zyxel PL-100
and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
http://www.zyxel.com/upload/images/app_diagram/app_pl100_550x0.gif
Apr 22, 2009 | Computers & Internet
New internet provider
Can you get one computer to surf directly from the modem? if yes, connect the router wan port to the modem
press the reset button on the modem and after resetting the modem, try to get an IP from your router
if it doesn't work, get the MAC address from comcast device and clone it to your router WAN MAC (hope this option is available on the router)
Apr 13, 2009 | Edimax BR-6104P Router
SonyVaio VGN-TZ398U/XC - Wireless WAN: Integrated Mobile Broadb?
You are not obligated to use Sprint. If you look at the first sentence it says "Optional Sprint....'
Yes you can use any carrier you want. Most new computers today come preload with AOL, Sprint, AT&T. In hopes you will choose one of them since it is already loaded, but not activated.
Feb 04, 2009 | Sony VAIO VGN-TZ398U/XC 11.1" Laptop
Computers & Internet Logo
David Payne
David Payne
