I am fitting a power commander to a 2002 triumph tt600 and the colours for the throttle position sensor dont match their diagram
SOURCE: Have an 08 Triumph Speedmaster Efi model. Put
the fuel is lean on the bottom, i dont know if the power commander can add some fuel or not. Why disconnect air injection, also if disconnected is the exhaust leaking.
SOURCE: "homeless" 2 wire connection plug on a 2002 Triumph TT600
Try this,If you can't see the details good enough,The plug you are talking about is for the exhaust air injection solenoid.
SOURCE: Triumph TT600 stalls during deceleration
under your air box on left side is kind of a round canister pretty small called stepper motor has 4 vacuum lines one from each carb annd 3/8 hose that runs up to air box usually 3/8 hose comes loose or falls off has to have good seal you can tell if its working look in from left side of bike through fairing when idling should see four vacuum lines pulsing if not check 3/8 hose and vacuum lines if all are intacked its probably the stepper motor they are two peice has teflon piston inside if bike ever went down oil goes int airbox down 3/8 hose into it and gumms it up run about $50
SOURCE: wiring diagram for 1980 triumph t140v ignition
Get a Haynes Manual. I work on my own bikes with a Factory Manual, The Haynes or Clymer Manual and a Parts Book. If you are going to do your own work you need these books. Period.
http://www.themotorbookstore.com/trium65twin1.html
Here are some simple diagrams that give the basic idea of what works for the Typanium Rectifier set up.
http://www.raskcycle.com/techtip/webdoc10.html
Here is a good site for "Home Mechanics".. I love this site.. has some great Triumph stuff and repair info.
www.jockeyjournal.com
Jim
Hi, I have a similar problem with my TT. My TPS harness are broken and i dont know the wires order. Please can you send me a picture? Thanks
